Use The Tractor, That's Why You Have It!!!
   / Use The Tractor, That's Why You Have It!!! #1
bp fick
Super Member
Beaver Creek, Northern Michigan
John Deere X390
Got this 5-600 lb bay window to remove. All by myself. Hmmmmm... get the tractor, that's why you have it, right? Done. :D:D
Told my wife she should have used the video setting.
   / Use The Tractor, That's Why You Have It!!! #2
Hook on and then....go ahead and back-up.:D
   / Use The Tractor, That's Why You Have It!!! #3
Wow, Kubota power ,,,I guess you are not going to put it back...Remodeling, a permaent occupation at home.
   / Use The Tractor, That's Why You Have It!!! #4
With my luck, the whole front wall of the house would come down with the window still attached. :(
   / Use The Tractor, That's Why You Have It!!! #5
Ditto that. BP, you're a braver man than me! Actually, I've got a bay window replacement in my future as well, and I guess you've given me another technique I hadn't thought of. Don't know if my better half would stay calm as I chained the tractor to the kitchen window. Stay tuned...
Come on, guys. You gotta know what's attached and what's structural. You've pushed out an old window or door before, right? Same thing.
I had prepped that bay, It was just setting in there, but tight as can be. But how is one guy gonna push a 9' bay window frame out? That sucker was heavy. You don't just jerk it all at once. You pull, very, very gently on this spot and that spot, watching to see how it moves.
Ah, an HST on the tractor is highly recommended!!
I've installed bay windows before, (along with 5 other guys helping hoist) but this was my first demo. It went very, very well.
It's really no different than pushing out a little 3x4 double hung, only on a much larger scale.
   / Use The Tractor, That's Why You Have It!!! #7
I just put this up a few days ago. Its about 700 lbs of mostly cast iron. Not the modern versions in aluminum. It takes a tractor loader with a pretty strong boom pole on the bucket to set this baby up on its feet (14' high).
‪July 21, 2011‬‏ - YouTube
Way too cool!!!!!
   / Use The Tractor, That's Why You Have It!!! #9
EXACTLY! And enhance it if you can.
   / Use The Tractor, That's Why You Have It!!! #10
I see your place is on the main line ... nice!
Is your tractor steam or diesel-electric?
   / Use The Tractor, That's Why You Have It!!! #11
Awww, where's the fun in doing things like that? I was kinda thinking of hooking up the Super M, put 'er in 2nd and pop the clutch. :laughing:
Actually, you've made a good demonstration of finesse and brute force working effectively together. Thanks for the inspiration!
   / Use The Tractor, That's Why You Have It!!! #12
Looks fun. I have a feeling if I tried that. I'd be pulling that whole wall out along with it.
Because I would have just yanked it hard because it wouldn't budge.
Then after the wall falls down. I realized that I missed about 15 nails. :laughing:
"Scratches head" Aw man, that's why the thing didn't budge. "Throws hat down". "Starts cussing".
Chad
Chad
Chad, Funny!! Actually, you aren't going to likely get every last one in a bay window, especially if the installer put them in goofy places 30 years ago. But you are right. Gotta get most of them. Two or three, here or there aren't going to matter much.
Once you gently stress the chain, the "free" portions of framing slip easily. If something isn't moving, that gives you an indication of where you need to work a bit more.
My strategy involved moving the bottom first. That weighed an easy 150 lbs, I figure. That wasn't really anchored much, so I knew it would "move". That is where the tractor was flat out, the right "tool".
The top, as you saw, was blind nailed and screwed. No way to get to them. It didn't budge. Once the bottom was free, I just broke the upright styles, to be honest.
That top portion had to weigh 200 lbs. That was a trip!!! It was anchored by long 3" drywall screws. No way that was going to just pull out. Had I just jerked away at full speed, it might have brought the header with it, perhaps. More likely the style uprights would have just snapped and that would have blown my opportunity to use them to pull the bottom portion out.
The pictures are fun, and posted for a bit of a laugh, but it was a serious job, actually. It wasn't quite as redneck a job as it appears, (not there's anything wrong with being a redneck) :D
   / Use The Tractor, That's Why You Have It!!! #14
thumbs up! :thumbsup:
   / Use The Tractor, That's Why You Have It!!! #15
I just installed the "3 TRACKS" signage below the crossbuck. The thing was getting kinda heavy so I left it off and then reinstalled it afterwards by hand. I was told that this crossing light was from the NY Central intersection at Hudson NY. You can go there in Google Streetview and let your imagination run. There is a CSX 8834 train at the crossing in a photo. And the 3 tracks...
   / Use The Tractor, That's Why You Have It!!! #16
BP, I build bay windows, and as such, can attest to their weight. Are you putting in a new bay or changing to a regular, flat window?
Joe
   / Use The Tractor, That's Why You Have It!!! #17
Nice job. From the looks of the grass you're getting pretty dry in MI like we are in OH...
Nice lookin tractor too.
Joe
Undecided. Almost leaning toward a french door look and wrap around deck affair? If we cheap out? double, double hung?
We've only had one meaningful rain event since late April. Ridiculous. My gardens have only had that one meaningful, natural precipitation all growing season. Didn't even get natural rain to sprout. Some relief tonight?
   / Use The Tractor, That's Why You Have It!!! #20
I might need you to talk to my wife. Every time I suggest using the tracter ofr something like this, I get "the look" and have to move on.
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
JLG 600AJ SKYPOWER TELESCOPIC BOOM LIFT (A60429)
JLG 600AJ SKYPOWER...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
Mahindra Max26Xlt Like New
Mahindra Max26Xlt...
2013 FORD F250 (A60460)
2013 FORD F250...
