Use of Timing Light on Golden Jubilee
   / Use of Timing Light on Golden Jubilee #11
Do you need to set the dwell on that tractor first?
I personally have never set or checked the dwell on these tractors. Just set the point gap correctly and moved on to other things.
   / Use of Timing Light on Golden Jubilee #12
On cars the dwell seemed pretty critical I’m not sure on a tractor.
   / Use of Timing Light on Golden Jubilee #13
The point gap (dwell) will affect when it sparks (slightly), so yes the point gap/dwell needs to be set before looking at the timing.
I've got my distributor cam lube next to the dwell meter.
Timing light and screw starters are in the tool chest.
Try connecting the pickup to the coil wire for more flashes on the timing marks.
Fun thread!
Ok, thanks.
The point gap (dwell) will affect when it sparks (slightly), so yes the point gap/dwell needs to set before looking at the timing.
I think I got that part right but I will tweak if necessary. Thanks for pointing that out.
   / Use of Timing Light on Golden Jubilee #17
When I set points by gap on cars, it was usually out of whack when I checked it with a dwell meter is why I brought it up.
Timing 101: Connect your timing light to the number one spark plug wire, they usually clamp around the wire and have two leads that connect to the battery for power. Assuming this has been converted to 12V, if it is still 6V then you will need a light that powered by AC or even an old style non-powered that connects between the spark plug and distributor.
Before starting find the timing mark you want to use, in this case 8 BTC, clean and mark it with a bit of paint on it and the stationary mark. I use white or yellow, to make it easier to see. With the engine at operating temp and idling @450 RPM point the timing light at the opening. The light, most have a button to push to make it flash, press the button while pointing the light at the marks and the strobing of the light will make the marks appear to be stationary. Loosen the hold down bolt at the base of the distributor a tiny bit so the distributor can be rotated by hand and GENTLY turn the distributor left or right to bring the stationary mark in the hole and the desired mark on the flywheel in line with each other. When marks are aligned, retighten the hold down bolt of the distributor and recheck timing to be sure it did no move.
NOTE: look as straight on to the marks as possible, looking at the marks at an angle WILL change your perspective of the alignment and cause the timing to be off by a few of degrees.
Ok, first attempt after attending timing 101. I think I did 2 things wrong. I used a toothpick and put a very fine paint mark on the scribed line for 8 degrees. The tractor would not idle below 550 or 600 rpm without dying. Probably need to adjust something on carb(or rebuild). For a first try it was not too bad but I could barely see anything on the 8 degree mark. Thanks for your help.
   / Use of Timing Light on Golden Jubilee #19
A bit bigger mark, think more along the lines of the thickness of a #2 pencil lead. As for the idle speed don't sweat it, a world of these have been timed at 500-600 rpm because they would not idle any lower. Plus a lot of people do not like for their tractor to idle that low, mine will idle down to just above 350 rpm but I usually keep it up around 550 because it just sounds better to me.
That small of a difference in rpm will only affect the timing by a degree or two at best, if at all. Depends on how sensitive you distributor fly weights are.
Thanks a lot. I will try again with thicker line.
2014 CATERPILLAR 279D SKID STEER (A51246)
2014 CATERPILLAR...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED AGT MX MRT14 STAND ON SKID STEER (A51247)
UNUSED AGT MX...
MURRAY 22" 2N1 SELF PROPELLED PUSH LAWN MOWER (A51248)
MURRAY 22" 2N1...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
