use for used hydraulic fluid?
   / use for used hydraulic fluid? #11
A rental shop owner I knew supplied filtered automatic transmission fluid for his chain saw rentals. (essentially the same product).
Tractor fluid would make a good 'summer weight' chain saw lubricant as it is a bit heavier weight.
Just filter it in case there are impurities present (like filings etc) that might mess up the pumping mechanism.
Shucks, and just changed my oil and dumped it! (forgot that I had 2 chain saws)
   / use for used hydraulic fluid? #12
"paint" trailer boards to water proof them
Dip fence posts
Spray road for dust
mix with diesel to reduce fuel costs
squirt onto hornet nests
use it to lube stuff from a sqeeze can
start a burn pile on fire (better than an old tire and you get in less trouble!).
   / use for used hydraulic fluid? #13
I put my $400 tire chains into the bucket of used hydraulic oil and put the cover back on.
Mike
   / use for used hydraulic fluid? #14
I'll bet it's a real PITA to put them on ....
I just hang mine up from a peg on the 6x6's in the pole shed.
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
Woods 3 PT Blade (A52349)
Woods 3 PT Blade...
2015 Clarke Power Gen 47KW (A50324)
2015 Clarke Power...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
