URGENT NEED FOR 1445 CHARGING VALVE
   / URGENT NEED FOR 1445 CHARGING VALVE #1
Raemelton
Adamstown MD
Power Trac 1445
Anyone:
We've blown the Charging Valve on our PT 1445. Tazwell is closed for the week...
is there an alternate source for this part? Anybody got a cross reference to another parts mfg?
-Steve
   / URGENT NEED FOR 1445 CHARGING VALVE #2
Welcome to TBN.
Hopefully someone can help you out.
   / URGENT NEED FOR 1445 CHARGING VALVE #3
I wonder if it can be temporarily Bypassed. Not ideal but......
Look in this group for a guy by the name of JJ. Send him a PM (he will probably respond shortly anyway). The guy is one of the hydraulic gods on TBN as well as a PT Owner.
   / URGENT NEED FOR 1445 CHARGING VALVE #4
It looks like a PT specific part. There are several parts to it. Depending on what you have blown, it may be repairable locally.
Mine has twice worn out the seals on the pressure regulating valve (the big spring at the tail end). I have never disassembled one.
My understanding is that this part takes a hydraulic input, and then uses a pressure regulator to pull off a 600psi+ (my memory of what Terry said) stream to relieve the brakes, and pop a second valve for full diversion of the remaining flow. There must be some bleed/bypass to remove the pressure on the brakes, but I don't know how it is done. If you rebuild it, you could probably guess at the pressure from a CharLynn catalog, when you reset the regulator pressure.
All the best,
Peter
Anyone:
-Steve
   / URGENT NEED FOR 1445 CHARGING VALVE #5
I heard that.
My 1445 does not have a charging valve.
I do have a charge pump which keeps the VSP pump full of fluid.
I believe the the newer PT hyd systems have an accumulator which is used with the brake system, and probably has a charging valve to pressurize the accumulator to a static/working pressure..
Is the valve below similar to what you are talking about.
Excerpt:
DESCRIPTION
This integrated package features a MICO Accumulator
Charge Valve and a Haldex W900 Gear Pump to accomplish
the accumulator charge function. The function of a dual
accumulator charge valve is to control the pressure in redundant
accumulators used in two or more brake circuits. When
the pressure in either accumulator decays to the specified
low limit a charge cycle is initiated. The flow rate at which the
accumulators charge is constant throughout the charging
cycle . The charging cycle is complete when the pressure
in both accumulators reaches the specified high limit. The
brake circuits are protected from pressure spikes at startup
by an internal pressure relief valve. Excess flow from the
valve may be used for steering, cooling or implement
functions. A relief valve is required for these function
http://www.mico.com/sites/default/files/documents/images/84-463-001.jpg?1346850702
   / URGENT NEED FOR 1445 CHARGING VALVE #6
Dear JJ,
That image looks like a great match. Well done!
Mine has a secondary, small, hydraulic accumulator attached. When I searched for it, the image above seems to be a Hydac design, and the manual is on this link. The Mico valves in the link in the previous post are a different physical design, but probably do the same thing. Parker also makes a version.
I don't know if the PT unit is a Hydac, but it looks close to me, and the ports have similar labels. BTW, I connected the vent port on mine back to the tank. I was tired of the oil blowing by the seal weeping out into the tub. PT makes a kit, which is a cut to length hose.
All the best,
Peter
SUCCESS!
Google "M930 Charging Valve"
Realize that it gets used in some coal mining equipment.
Skip over all the "BreakTender" entries (That is Power Trac too...and also closed all week)
Discover KET Inc. in Raven VA ... an awesome mining equipment repair and parts outfit.
Call. Buy. Overnight. Install.
WORKS!
-steve
Thanks to all for suggestions
   / URGENT NEED FOR 1445 CHARGING VALVE #9
Great to hear that you got it fixed!
I'm curious what the price was? (Not including the special 4hr rush freight. :laughing: )
All the best,
Peter
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
7046 (A50322)
7046 (A50322)
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
Landoll Hauloll (A53472)
Landoll Hauloll...
FAKE (A52472)
FAKE (A52472)
2009 Mazda 3 Sedan (A51694)
2009 Mazda 3 Sedan...
