Upper HYD. Link
   / Upper HYD. Link #1
Bedlam
Veteran Member
I am posting a few pics of my Hyd. upper link I just got done building.Hope it give people some ideas. I got my original from the forums, and glad for it, as I had never heard of such a thing before.
I bought a piston from 3" x 10" x 2" piston from surplus, for 49.99 dollars, and two three foot 1/4 inch hoses. (1/4 inch so that the flow would be slow enough ) and four 1/4 inch quick disconnects.
I bought two link end repairlinks from a company in Maine for the ends.One end of the piston was flat.(no clevis etc) I extended the rod out, and packed that end with snow, to cool it. I then welded the link to the flat end.
The opposite end had an eyelet of 5/8. I stood the cylinder on end in the vice and sawed a slot into it and slid the repair end into it, and welded it. That end of the rod was 2" .and would interfere with the impliments end, so I used a circular saw and metal blade and make a 45 degree angle.
Luckily, I had a valve that feeds the swing on the plow. So I put in a 1/4 inch "T' to power it.
I ended with 17.75 inches retracted. And 27.75 extended.(got the 10 inch stroke).
All together, I spent just about 145. dollars for materials.
For my use, I wont miss the check valves...
I did encounter one stumbling block tho. It has SAE 4 ports. I was in a rush, and didnt notice that when I ordered.
They have adapters from this o ring seal thread to 1/4 inch but I forgot to buy them. I ended up spending another two hours hunting two down.
Allan
   / Upper HYD. Link
and another
   / Upper HYD. Link
and the flat end link.(excuse the welding)
   / Upper HYD. Link
and the last one..
   / Upper HYD. Link #5
Good job /forums/images/graemlins/cool.gif /forums/images/graemlins/grin.gif
Ain't nothin like the satisfaction of /forums/images/graemlins/cool.gifdoin it yourself
   / Upper HYD. Link #6
Very nice job, have you had a chance to use it yet? Thanks for posting the pics.
   / Upper HYD. Link #7
Nice work! I'm waiting for my cylinders to get here (Friday!) so I can do the same. It's always nice to see others doing projects that I've been thinking about in my crazy head!
Have you used it yet? Does the cylinder stay where you set it?
The reason I ask, is that several here swear by using pilot-operated check valves to hold the cylinder in place. After reading and searching until I was ready to die, I've decided to build my system without them.....I'll see what happens.
   / Upper HYD. Link #8
</font><font color="blue" class="small">( ....................several here swear by using pilot-operated check valves to hold the cylinder in place. After reading and searching until I was ready to die, I've decided to build my system without them.....I'll see what happens. )</font>
Keep it simple .....
Unless you have a leaking valve you will be OK.
IMHO the pilot operated check valves are WAY over rated, they are a band-aid for leaking valves. They WILL NOT stop a cyclider from "leak down" if the internal o-ring on the piston in the cylinder is leaking fluid past it... period. I'm sure this is going to "go over well" with those who swear by pilot operated check valves and spent the extra money on them. no disrespect - to each his own. /forums/images/graemlins/tongue.gif
P.S. They can be dangerous
Speaking of safety - Hydraulic police speaking here....
Please replace those rusting low pressure fittings on that valve with genuine hydraulic high pressure fittings - They can blow up sending metal fragments flying. /forums/images/graemlins/shocked.gif
   / Upper HYD. Link #9
Well everyone here is entitled to their own opinion that's the beauty of this site. Will say that both of my T&T cylinders were purchased with double piloted check valves and they don't drift like my FEL cylinders do once set.
There have also been more than a few here that purchased cylinders without the check valves and have used them without complaints. Then there have been a few that replaced the first cylinder with a second cylinder that incorporated a check valve. Common sense tells me that there was a reason that they spent the extra dollars and made that changeover. Maybe a good member that has made that change will jump in here and shed some further thought on this, what say thee Jim? /forums/images/graemlins/wink.gif
   / Upper HYD. Link
Thanks, Well, Have I used it? the answer would be yes. It seems to work well. I haven't used it hard yet, Such as with my rake etc. But Ill soon be able to tell.I havent seen alot of leak down on it yet. but I usually leave in in the down position and move the lever back and forht a bit to have it settle.I think, maybe the decision to have a check valve or not, would be the price, but more so the need for it not to leak down.For my application, a bit of leakage would be ok. I am mostly looking to be able to change the blade pitch witout the turnbuckle upper link.
The cylinder was the cheap one, it isnt rebuildable, (welded end). HMM .. altho I guess you could grind the weld off and rebuild it. But that just wouldn't be worth it.
I'll give more feedback when I get out and use it more.Still winter where I am and the ground is frozen.
One poster was asking for info on why others have changed out their cylinders. That would be good to know.
Allan
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
City of Buckhannon - 2000 Chevy 2500 (A52384)
City of Buckhannon...
INGERSOLL RAND G70 GENERATOR (A52472)
INGERSOLL RAND G70...
