Buying Advice Upgrading BX24 to L3800
   / Upgrading BX24 to L3800 #1
Tipper
I'm in the final stages of a decision to upgrade BX24 to L3800 loader/BH. I see the Hydraulic pump capacity is 6.3 gpm/3.8 gpm (PS). This looks lower when compared to others in the same hp range. (L3240 is 8.3/4.9) Any thoughts if this will impact performance in any way? or not to worry as it's an ideal pump capacity for the design?
I will push the loader and backhoe hard as I have a 10 acre lot to work ... bush cutting, tree planting, prep for cottage build, and make a 700 foot driveway (Box Scrapper) through a hayfield, etc. This will be a long term project over the next 2 years.
I don't want a bigger tractor because it will be moving between home and cottage throughout the summer months.
   / Upgrading BX24 to L3800 #2
hydraulic flow = speed. Pressure = force.
This is what I found about my tractor. I think for most applications like FEL etc. the pump is plenty. When needing a back-hoe to run off the tractor hydraulics the lower flow means a little slower response but it will still be strong.
1999 FONTAINE 48X102 FLATBED TRAILER (A51222)
1999 FONTAINE...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
2005 Kobelco 135SR Hydraulic Excavator (A50322)
2005 Kobelco 135SR...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
2002 STERLING LT9500 DAY CAB (A51222)
2002 STERLING...
Land Honor Portable Screener (A50514)
Land Honor...
