Upgrade the hydraulic pump?
   / Upgrade the hydraulic pump? #1
jimmer2880
Platinum Member
Hagerstown, MD
'05 Kubota BX1830
Has anyone swapped out their hydraulic pump for a higher output hydraulic pump?
After adding my FEL & Power Steering, it appears that I could use a bit more flow.
There doesn't seem to be enough room to add a belt mtd pump. I'm don't want to add a crank pump because I hope to run my MMM from there someday. And, since my MMM is currently spinning off of the rear PTO, I can't use that either.
So, that leaves trying to upgrade the existing pump to a higher capacity pump. According to the parts manual, it looks like the gear drive slides onto the pump with a key'd shaft. If that's the case, I wonder what the odd are, of finding a larger pump, with the same bolt pattern & shaft size?
I figure I'm up the peverbial creek on this, but figured I'd ask anyway.
   / Upgrade the hydraulic pump? #2
It would not surprise me to find a pump with a little more capacity that would bolt in the same location. What is the cc's/rev on yours? Often it will be on the tag. By the way, could you have some sort of coincidental problem with your hydraulic screen/filter getting plugged? I know you just did the PS and loader, but check the basics once again just in case. A little water in the hytrans, cold weather and a partially clogged screen will bring things to a standstill. Just a thought.
Very good point on the clogged screen/filter. I was planning on changing the hydraulic/trans fluid after a couple hours. I'll try this first.
I will also take a close look at the pump to see if there is anything english stamped on it.
I was able to get some info off of the pump. Although, I dont' know how much good it will be.
Make: Kansaki Koki Corp
Model: GP1-C-5C
Pressure: 140 (I think it's kg/ something. I couldn't make out the something)
Discharge: 5cc/rev
Now, how on earth does anyone determine how much GPM that 5 cc/rev equates to?
I was able to find a web site for the company I believe is Kansaki. However, they were extremely little help.
   / Upgrade the hydraulic pump? #5
At 1800 rpm, you would have 1800 x 5cc, or 9000cc/min, which is 2.4 gallons. At 2500 rpm, it would be 3.2 gpm. It would nice to see 5-7 gpm.
Someone check my math, this seems low.
The conversion I found was:
1cc/min = .000264 gpm
so, 5 cc/min = .00132 gal/min
1800 RPM = 2.38 GPM
2500 RPM = 3.30 GPM
That doesn't look so good. I think I found why my F16 can't handle PS AND a FEL and a 3pt :(
   / Upgrade the hydraulic pump? #8
I think here may be a pump with 25% more capacity. I've replaced pumps with the larger pump to gain capacity. Email me if you are interested.
   / Upgrade the hydraulic pump? #9
Anything much larger than 25% gain would make a person have to look at the size of the factory suction and pressure lines, filter, screen, etc. Although I think the lines would work up to around 6gpm.
email sent. Thanks
2017 KOMATSU PC290LC-11 EXCAVATOR (A52706)
2017 KOMATSU...
2006 JLG 2030ES 20ft Electric Scissor Lift (A54811)
2006 JLG 2030ES...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
KUBOTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUBOTA M6800...
