Upgrade old "B" headlights to new "B"
   / Upgrade old "B" headlights to new "B" #1
Adam23
Upstate, South Carolina
Kubota B7500
I have a B7500 with the old round headlights that do not produce alot of light and was thinking of upgrading to the B7510/7610 headlights. It looks like the whole plastic front peice that holds the headlights in should be universal between the 2 series of tractors. The metal hood and plastic headlight frames look like they should interchange. Does anybody know if this will work? Part number/price? I think that the new style headlights are much brighter and better for night mowing. Any thoughts?
   / Upgrade old "B" headlights to new "B" #2
You'll "pass" a concrete block once you do get the ##'s and price! I broke the clear headlight lens out of my B3030 and wanted a new one ( wrongo !!) the whole front assy..from lens to lens with the plastic piece that goes between them ( now..for a short pause...the clear lens IS removeable...but you CANT BUY THAT!!) set me back more than $150.oo........:eek:
Doesn't the 3030 have the slanted hood as the 7510 does not. I think the 3030 headlights are different. I could be worng though. That is expensive!
   / Upgrade old "B" headlights to new "B" #4
I took the B7800 head light assembly out thinking I could drop some halogens in it.
Not any way I could see to do so. They seem to be sealed.
   / Upgrade old "B" headlights to new "B" #5
Adam23 - A less expensive alternative would be to replace your OEM 15 watt bulbs with 50 watt bulbs, as shown in the link below:
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=OPR&MfrPartNumber=A701
I have been using 50 watt Blazer (which used to be available locally) bulbs in my 2003 B7500 for several years. IMHO, the 50 watt bulbs provide significantly more light, although I do not use the tractor much at night.
   / Upgrade old "B" headlights to new "B" #6
If you have plastic headlights I would be very careful going from a 15w halogen to a 50w halogen. Halogen bulbs generate very high temperatures, a 50w could possibly produce 3x the heat you light was make to handle. Really only one way to find out.
   / Upgrade old "B" headlights to new "B" #7
Just mount a new light on the hood. Disconnect the original ones and use their plug in for the new one.:D
   / Upgrade old "B" headlights to new "B" #8
Ray66v - The A701 is incandescent, not halogen, but 50 watts is more heat. My headlight lenses are plastic. So far no sign of damage to the lenses, reflectors, hood. Again, I do not use the lights much.
   / Upgrade old "B" headlights to new "B" #9
I too have used the 50 watt Blazers in my B7800 will no ill effects but I don't use my lights much either.
How much were these Blazer bulbs and where is a good place to get them. Are they a direct plug-in?
John Deere 637 Disk (A50514)
John Deere 637...
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
2011 Cadillac SRX LUXURY (A50324)
2011 Cadillac SRX...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
