Upgrade from CK2610 to DK5310?
   / Upgrade from CK2610 to DK5310? #31
youll find the DK series is alot sturdier machine than the CK series. everything on it fron the hydraulic cylinders to the ...name it, are heavier duty.
i compared the 2 when purchasing mine. 12 years later no regrets.
but i hope you didnt lose much $$ trading in such a new tractor
The DK seems a lot more stable than the CK. Seems more planted, prob because it is a lot wider.
   / Upgrade from CK2610 to DK5310? #34
Omg so muddy. The tires filled up right away, but maintained traction better than the R4’s. I asked for the R14’s and they threw em in for free. Let me just say this, in the 15 min that I played with it this morning, the two machines don’t even compare. Everything is better on the DK. EVERYTHING.
I had hooks welded on. They are so useful.
The DK is of course more capable, but in general operation it really feels that much better?
I think so. I put 159 hours on my CK since June 1st, so I’ve had some time to see its limitations. 30 minutes on the DK, I already knew upgrading was a good choice. The loader seems more precise and controlled. The machine is quite a bit wider which gives it a more planted feel. Going over uneven ground with the CK always had me on edge. I can’t get over how quiet the engine is, even at higher RPM. The power difference is astonishing. My driveway is a big long hill. The ck did fine in medium, but would stall in high. The DK drives up in high range without even breaking a sweat. There is also a lot less hydraulic pump noise. I actually didn’t even notice much of a noise. The DK loader bucket is a lot bigger than the CK, 6 cu ft bigger. I haven’t don’t lot with the machine yet, but I suspect I won’t be disappointed.
Misc Top Mount Water Dispensers (A54816)
Misc Top Mount...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A55315)
2023 Kubota L3560...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
2018 Ford F550 Chassis (A55973)
2018 Ford F550...
