Upgrade Advice
   / Upgrade Advice #1
nj1026rguy
COLUMBIA
2012 JD 1026R
Hey All,
I am new to the forum and have been doing a bit of research to upgrade from my JD 1026R. I currently have about 11 acres, mostly all wooded. I have had the 1026r for about 4 years now and it seems a bit to small for my needs. I have a 1300' driveway that I will either plow or snow blow, property cleanup (down trees from Sandy etc, so a grapple might be a good implement) and hauling firewood ( i have a large dump trailer that I use), and your basic FEL work. So something with a mid mount PTO, more lift capacity ( front and 3pt) and a heavier machine would be ideal.
I have been looking at some used tractors 30-38hp range from JD, Mahindra and New Holland. Any suggestions on models etc that I would key in on for my needs?
Thanks again,
   / Upgrade Advice #2
Kubota L series, JD 3 series, Yanmar YT235 would all work well for you. The Korean brands, LS, TYM, Brandon, Kioti, are all good too.
The New Hollands are rebadged Korean LS tractors. If you're shopping NH compare to LS, there may be a cost savings. The smaller Mahindra's are rebadged Korean TYM tractors.
What dealers are closest to you? And what's your budget?
   / Upgrade Advice #3
The mid-pto seems to be used more on the smaller size machines. If mid-pto is a must, that's going to limit your options quite a bit.
   / Upgrade Advice
Mid PTO is not a must, I just thought maybe for future snow blower needs. My budget is under $20k with loader.
   / Upgrade Advice #5
Take a look at the LS XG3135. Wide stance, 35hp, huge loader lift capacity. New with shuttle shift tranny should be $17k.
2014 Club Car Electric Utility Cart (A51691)
2014 Club Car...
ITEM LOCATION (A53084)
TEST BID LOT (A50775)
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
2011 DOOSAN ALL TERRAIN FORKLIFT (A52576)
2011 DOOSAN ALL...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
