Update on RX6010 with low hours motor failure
   / Update on RX6010 with low hours motor failure #81
Keeper shearing results in valve drops and subsequent collateral damage, like broken crankcase cylinder walls and pistons and rods exiting the crankcase. The block heater would be part of the collateral damage.
If the op has no knowledge re how an engine functions and operates, he痴 going to have a pretty tough time arguing that the failure was a manufacturing defect.
Pictures, in detail, of the failed parts would help his case, but if all he has is a photo of the collateral damage, he isn稚 supporting his case very well.
Forensic engineering is a science all by itself, and requires a detailed understanding on how things work.
   / Update on RX6010 with low hours motor failure #82
A part failure I might expect considering hours on the machine is a valve spring. 'Surge' (harmonic-caused fracture at a node/weak point) can cause a spring to fail, then drop its retainer and let its keepers (sleeves?) loose.
A cylinder liner can be called a 'sleeve', and we may have been thrown off by OPs misunderstanding a mech mention valve-train 'sleeve' as a cause vs another thing that suffered catastrophically. (piston shoves loose valve up to wreck rocker or other valve-train bits ... 'interference engine')
I'm not so sure the heater 'blew out' or whether the block may be busted at least as bad as a head. For us to have the coolant drip video to work with isn't much. Dramatic, maybe, but you can't tell what kind of car a raccoon was run over by just from finding it by the roadside.
Can we be sure, third hand, what broke first and what it then 'took out'? Hmmm ... The less pertinent info we have to go on, the more and wilder guesses we get, right? :)
   / Update on RX6010 with low hours motor failure #83
I have seen several post referring to the minimal number of post by some.
While I agree with the thought process and the general correctness of this idea, let me play the devils advocate.
I have been here a while and I do not have all that many posts. That is because generally there are many well educated and highly experienced people here whom have have given an answer equal to or better to what mine would be, or I do not feel my answer would help.
There are a lot of people here that have less knowledge or experience than others.
If that is the case, then when they voice a complaint, they should not be vilified for not having "enough" posts.
They might be wanting to get involved and make a post, but just do not have words that they feel would be worthy of posting.
Again I am just playing the devils advocate. This is not meant to be in response to any one specific, just saying.
<><> AGREE FULLY ! Also some that are here for only a couple of months and have 1500 posts...most of those posts with nothing to say contributing to the discussion!
9 pages impressive.
When I can get a better accounting of what when wrong I’ll be sure to share it here.
Like I work for another company, yeah and the earth is flat. I’m just a 61 year old married guy with a tractor that died and I’m putting new motor in it with the help of my local bank. And I actually have better things to do with my time than discuss my tractor problem on this forum very much.
I’d actually post a link to my business here but given the wacko theories here I don’t need some Internet freak showing up on my doorstep because they think I’m lying about their favorites tractor brand.
Thanks for your support and trust. Typical of many today, don’t believe anything if it conflicts with what you want to believe.
Merry Christmas.
   / Update on RX6010 with low hours motor failure #85
VTDT....I hope the engine swap goes good for you....Merry Christmas to you, too!
   / Update on RX6010 with low hours motor failure #86
9 pages impressive.
When I can get a better accounting of what when wrong I値l be sure to share it here.
Like I work for another company, yeah and the earth is flat. I知 just a 61 year old married guy with a tractor that died and I知 putting new motor in it with the help of my local bank. And I actually have better things to do with my time than discuss my tractor problem on this forum very much.
I壇 actually post a link to my business here but given the wacko theories here I don稚 need some Internet freak showing up on my doorstep because they think I知 lying about their favorites tractor brand.
Thanks for your support and trust. Typical of many today, don稚 believe anything if it conflicts with what you want to believe.
Merry Christmas.
If you had better things to do WHY discuss it here in the first place?Good luck..
   / Update on RX6010 with low hours motor failure #87
@VTDT- I too hope the swap goes well and you're able to get this machine back to work. If you are able to post any updates about what caused the failure if/when you get them, that would be great, though I'd understand if you dropped this forum and never came back. In my opinion you've been treated rudely by some. Which isn't just inappropriate, it's a loss for you and the community. It means the larger community will miss out on learning something- what caused the failure in your machine. It may turn out to be a badly designed engine, operator error, bad luck, or something else all together. As a tractor owner/operator I'd like to know so I might be able to avoid it myself. When new forum members are ridden off early, nobody wins.
Merry Christmas and best of luck.
   / Update on RX6010 with low hours motor failure #88
Have you considered selling the machine as is? I'd love a tractor project.
Regards, Fred
   / Update on RX6010 with low hours motor failure #89
9 pages impressive.
Thanks for your support and trust. Typical of many today, don稚 believe anything if it conflicts with what you want to believe.Merry Christmas.
VTDT, I'm sorry to hear about the problem, but the response you got was your own doing! You came here with conjectures: no pictures, no facts, no description only your opinion of what the company should have done on warranty expired a year earlier. What did you really expect? People taking your side blindingly? Without knowing you level of knowledge about tractors/mechanics and other things how do we know that it wasn't you who caused the damage? As a lawyer as you claimed to be, you ought to know that clarity of facts is paramount, what we got instead is the night & fog treatment or the mushroom diet. Don't blame others for your shortfalls, that too is typical of ignorant people.
   / Update on RX6010 with low hours motor failure #90
Two years ago and well out of warrantee - Kubota fixed a problem on my tractor. Three house calls and finally a tech who saw the exact problem. Less than $4 in parts & ten minutes late - a permanent fix. I offered to pay but they chalked it up to good customer relations.
Had it been a blown motor - I would not even ask on my nine year old Kubota.
(8) 12" CHANNEL IRON (A57192)
(8) 12" CHANNEL...
INGERSOLL RAND SD-100D SMOOTH DRUM ROLLER (A52707)
INGERSOLL RAND...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
6-Band Wooden Barrel (A55853)
6-Band Wooden...
Black Metal Roof Panels (A55758)
Black Metal Roof...
UNUSED RAYTREE RMA42 HYD AUGER SET (A57193)
UNUSED RAYTREE...
