Update on loader repair program from Kioti Jan 30
   / Update on loader repair program from Kioti Jan 30 #61
Well Hodak, will you be buying a Kioti cab tractor?;) :rolleyes:
I agree about Bob's comments, I have yet to get upset by what he writes. Nothing wrong with hearing different opinions and ways to fix the problem.
   / Update on loader repair program from Kioti Jan 30 #62
Question, are these loaders made in Korea or did they outsource and manufactured in the USA?
   / Update on loader repair program from Kioti Jan 30 #63
shvl73 said:
, what good is having two loaders for one tractor? I hope you guys get some good news soon on your loader issues.
You're right. No need for two loaders. Anybody want a used KL130 with cosmetic cracks? Anyone??? Ok, that's just being a smart a**. Sorry.........
I'll try and hang in there a little longer. It is fun to shop again though. :)
   / Update on loader repair program from Kioti Jan 30 #64
IslandTractor said:
I agree with Bob and others who have identified the critical potential safety issue: cracking that could suddenly cause the torque tube to separate under load. . .
The cracks on my loader were first noticed a year ago . . . after another 40-50 hours of fairly loader intensive brush clearing, the cracks had clearly extended and are now visible without removing the inspection plate. I don't see any reason that with continued normal use and flexing of the torque tube why these cracks would not continue to spread.
Ed, I'm not a metalugist, but I have a little experience in metal shearing and I doubt that simply driving with a loader that has a cracked torque tube will lead to a roll.
But imagine driving into a settled pile of topsoil and sod, or pile of clay. That is a fairly common task for many. Now what if the cracks tore around the tube after several trips of moving bucket loads of this settled soil pile?
First
you'd have to presume you already have a cracked loader. Like yours. Second, you'd have to presume the cracks have continued to grow. Also like yours. Third, you'd have to presume that they will continue to grow and that stress caused by using the loader, and driving into the pile will increase the cracking.
Now that the situation is set up, and is realistic, presume you are driving your tractor into that pile and your torque tube breaks upon initial contact with the pile. The likely scenario is that the side of the loader that meets the most resistance will compress and twist while the other side of the loader will not and that will likely cause the tractor to twist and roll.
Another scenario is with the same damaged loader, carrying objects that are both heavy and subject to shifting in the bucket. Under that circumstance a break could cause a similar twisting and potential roll.
   / Update on loader repair program from Kioti Jan 30 #65
I presume someone will respond to this. I imagine I won't.:)
   / Update on loader repair program from Kioti Jan 30 #66
To my knowledge the KL120 & KL130 are made in S. Korea & are outsourced by Daedong/Kioti to a 'original equipment manufacturer' in S. Korea.
Moss road writes:
It is faily obvious that everyone agrees on the three following items:
1. Yes, there are cracks.
2. Yes, they should be repaired.
3. Yes, it is taking the company too long to get them repaired.
There isn't much left to talk about other than updates to the status of the repair process...
I agree. Let's keep it on topic. If a poster wants to talk about all the numerous possibilties of what could or may or be remotely possible concerning unbalanced loads etc....start a new thread in the safety forum.
Don
   / Update on loader repair program from Kioti Jan 30 #67
Hello folks, I am patiently waiting in agony along with everyone. Failure of a strucural member by cracks in a lifting device are a safety issue. If there was a crack in the fender, not a safety issue. The example of the crane is perfect, a cracked structural segment of a crane shuts the machine down. If that torque tube wasn't an essential structural element then it wouldn't be there.
I have a question that is related to this. You have two loader rams holding the bucket up. The rams are linked hydraulicaly without check valves. So if the one ram suddenly takes all the load and is overwhelmed by say.. a broken torque tube, would the other ram actually extend as the overloaded ram is compressed? Wouldn't that act to put the tractor into a roll?
Thanks for keeping this issue alive. I hope for the best here. The tractor has been great for me after nearly 400 hours, the loader has been the only failure.
   / Update on loader repair program from Kioti Jan 30 #68
This sounds plausible to me. :eek:
   / Update on loader repair program from Kioti Jan 30 #69
coasterez said:
My opinion: I can't see how the cross tube affects safety unless coupled with another failure. Isn't this cross member there to provide lateral rigidity . . . If you cut the cross member completely out, wouldn't the bucket still operate? It might twist . . . But, unless a cylinder fails, I don't see where a failure of the cross member by itself would cause harm
As I attempted to express earlier, the cylinders work in series but I probably did not express myself clearly because Highbeam more clearly states what I attempted to write, but he wrote it in question format.
Highbeam said:
Failure of a strucural member by cracks in a lifting device are a safety issue. . . If that torque tube wasn't an essential structural element then it wouldn't be there.
. . .You have two loader rams holding the bucket up. The rams are linked hydraulicaly without check valves. So if the one ram suddenly takes all the load and is overwhelmed by say.. a broken torque tube, would the other ram actually extend as the overloaded ram is compressed?
That is my point. Please realize this would likely only occur if the loader was at or near capacity.
Also understand, as is clear that Highbeam does, that the cylinder does not hold the load, but it is the fluid in the cylinder that holds the load. So if a cylinder is overloaded, as would occur with an uneven load or a load shift in the bucket, then the overloaded cylinder would compress, the natural action is its fluid would move to the other cylinder and cause it to extend. This is all in absence of "check valves" or more correctly in the absence of double piloted check valves, and those simply do not exist in loaders because the torque tube is there to prevent this problem. If the torque tube cracks through and the loader is at/near capacity, then there is a big potential problem at hand.
   / Update on loader repair program from Kioti Jan 30 #70
Cota said:
Hey by the way---Kioti is a great tractor.
There you go again with the free flowing propaganda..... I feel more balance is due here in this forum. The Kioti is a poor tractor of marginal build quality, with meager sales and woeful public relations campaign. ;)
2015 Komatsu WA380-8 Wheel Loader, S/N A74124, PIN# KMTWA130CFNA74124, Diesel Engine, Komatsu WA380 (A59076)
2015 Komatsu...
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A58017)
2016 FREIGHTLINER...
2008 Chevrolet Express Box Truck (A56858)
2008 Chevrolet...
2013 Chrysler Town and Country (A56859)
2013 Chrysler Town...
15200 (A56857)
15200 (A56857)
