update on crazy 6.0
/ update on crazy 6.0 #1
Robbie Hegwood
Platinum Member
Georgia
Took my truck to Ford thursday for passanger mirror replacement and asked them to check the surging problem. A phone call later reveiled several things we dicsussed in the earlier thread. They said they were ordering me a new turbo and should be in tomorrow. Apparently the silenoid for the turbo veins stuck wide open and hung there damaging the impeller. That was the high boost reading on my uphill climb. They replaced the whole turbo with a new design under warranty, no questions asked. Good Ford dealer. The same mech worked on it this time as last. I talked to him and he hinted and asked if I had run a chip, I answered NO because he recommended not. That was that and he said the sticking silenoid was a problem he has seen before.
I did buy some cetane booster and now my 80k stroke has a new turbo. Thank God for leading me to the purchase of that truck with a warranty for who knows how much the bill would have been otherwise.
Hopefully with my new knowledge of turbo diesels I can help my truck live a little longer. Later Robbie
/ update on crazy 6.0 #2
Another situation that makes the solenoids stick is not enough cool down time. If the turbo is being used even at normal driving and then the truck is just shut down as soon as you stop with no cool down, it can easily damage the turbo. This may not be your case but a good habit of letting the vehicle have a solid 1-2 mins of cool down at idle can elongate the life of a turbo. Maybe even look into buying a turbo timer.
Some remote starters, like my Bulldog remote stater, have an idle setting where you just hit start with the vehicle running and you can take out the keys and lock up the truck and it will idle for 5 minutes before shutting off.
GMC 2500HD 4wd Service Truck (A63689)
GMC 2500HD 4wd...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
2002 Ford F-250 Service Truck, VIN # 1FTNF21L52EB33349 (A65563)
2002 Ford F-250...
