Up exhaust it or not?
   / Up exhaust it or not?
dirtworksequip said:
To remove the vertical exhaust pipe you grasp it at the guard and lift up. You may have to wiggle it a little. Its a good tight fit. Then you can lift the hood as normal. The only drawback to the verical exhaust I have seen yet. When working in the dark the worklights reflect off it somewhat,but the other advantages outweigh that.
http://i138.photobucket.com/albums/q259/dirtworksequip/vertical%20exhaust%20removal/P1010945.jpg
dirtworksequip, good pic, can you provide a shot of it that shows it all the way to the top?
BTW, what type of cab is that Curtiss?
   / Up exhaust it or not? #16
Nuru said:
yes it does. Great looking Cab, i just figured out that is the Stock cab for your unit. i was wondering if there is something close to that available for my 4310?
No OEM cabs for your series of tractors. Curtis Cabs makes hard and soft sided cabs for your tractor. They don't look bad but don't have the creature comforts and fit of a OEM.
   / Up exhaust it or not? #17
At least you got a cab! My 1070 has the 'up' exhaust but no cab, so after runnin that thing all day I can say that I stink. But with this new bio-diesel we're using at work, I'm not sure if I smell like a french-fry or not.
   / Up exhaust it or not? #18
Just to balance the discussion a little bit, I have a 4310 with a Curtis cab and standard exhaust. I hardly ever notice the exhaust odor and don't have any big hankering to replace the exhaust with a vertical one. My stock exhaust pipe does a good job blasting the exhaust forward and left, to the point where part of the front mounted blower gets some black residue on it each winter.
The vertical exhaust does look kind of cool, though.
To each his own.
Tom
   / Up exhaust it or not? #19
unit40, not so sure I'd want to smell like a french fry if I were in bear country!
TMcD, the biggest problem I found with the stock exhaust was that when hand unloading anything out of the bucket with the tractor running put the exhaust right in my face.
The other thing I did not care for was that while brush hogging or mowing the exhaust blew up a lot of dust. And even being in the cab I did'nt care for that.
   / Up exhaust it or not? #20
Yep, I can see how that could bug you.
Tom
20'x20' High End Carport (A53316)
20'x20' High End...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
60" EXCAVATOR BUCKET (A52707)
60" EXCAVATOR...
84 Snow Removal Quick Attach Bucket (A47477)
84 Snow Removal...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Mercury 60hp Boat Motor (A54865)
Mercury 60hp Boat...
