Unused older torch set
   / Unused older torch set #1
luvmexfood
Lebanon, VA
Long
I have a set of torches and gauges that haven't been used in probably 15-20 years. Found a place that will swap out bottles so gas is not a problem. What are the chances of the rubber o-rings and associated rubber parts being dry rotted? I saw a place on the internet that will rebuild them. Is that a good option or should I just replace all. They will see infrequent use.
   / Unused older torch set #2
O-rings are cheap and should be the only rubber parts. Change em. Try a few settings on the regs and see if they hold. If so, Good to go. There are a lot of torch sets out there that are 25yrs old that work and get used daily. Depending on the brand, yours could be one of them.
   / Unused older torch set #3
My O/A set is a Linde W-200 from 1985 with welding and cutting tips. Still works fine.
   / Unused older torch set #4
How are the hoses?
I was in about the same position:
http://www.tractorbynet.com/forums/welding/318494-old-tanks.html
But I got an obsolete torch with no tips available and no cutting attachment, the hoses were suspect, and the Craftsman regulators didn't look all that great. I bought a new Harris set.
Getting the lifetime lease on the tanks for $50.00 was where I figured the real value was. The new torch was peanuts compared to the cost of leasing tanks, or buying my own tanks.
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53473)
2017 Ford F550...
ATTENTION PLEASE READ (A50123)
ATTENTION PLEASE...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A53473)
2022 Gravely...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
Power Liner 4000 Paint Striper  (A52384)
Power Liner 4000...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
