LostInTheWoods
Platinum Member
Completed 50-hour maintenance (46.2 hours, actually) today...
While checking over the tractor (BX 2660), I see two bolts protruding from the front axle case. One on each side. The one on the left is sticking out about 1/2 inch, the one on the right is out a solid inch.
No problem, I'll just tighten them up. Takes a little elbow grease, but the one on the left goes back in OK. I get the one on the right about two-thirds of the way back in, and the bolt breaks (shears?). Like I said, it took some effort, but I wasn't trying to force it to keep turning after meeting too much resistance. I was turning by hand (no powered equipment).
Did I do something wrong, or is this an engineering problem? Is this something that was missed at the factory/dealer, or do bolts on axle cases typically work their way out after 40-50 hours? And now that I have this bolt more-or-less stuck, is this a warranty repair?
Many thanks,
Lost
Many thanks,
Lost
