rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,675
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
This sounds fascinating.... just the sort of project that we look forward to doing: Making it better with little to no chance of making things worse. Plus the chance to learn something in the bargain.
I also like the idea of witness marks both before and after. That will tell you what change actually took place. Can't wait to hear how it all turns out. Take some photos if you haven't yet. I have a feeling that this is common to lots of loaders.
Engineering wise, bolted joints should hold under clamping pressure alone. Bolt holes are allowed to be a specified amount oversized. So if the clamping pressure is not holding it firm, the answer is to go with larger or higher strength bolts so that you can use higher clamping pressure i.e. more torque on the fastener bolts.
Best of luck,
rScotty
Best of luck,
rScotty
