Jmsvickers
- Joined
- Apr 16, 2019
- Messages
- 11
- Tractor
- Kubota L2501DT
Hi all, I have a unknown make model wood chipper that I borrowed from my folks. They got it and never used it but a handful of times but my pop said it kept jamming on him. I took an look at it and noticed three rows of the feeder roller teeth snapped off. It looks like the manufacturer used some type of hard rack teeth for the roller teeth. Unfortunately (or maybe luckly) the welder must have been hung over when they made it as there was zero penetration into the teeth. I made some teeth for it out of mild steel that were the same height as the factory teeth.
I put it all together and fired her up using my kubota l2501 and everything looked good, I put a stick in it and it wouldn't feed still..... the blades are plenty sharp as the cuts are incredibly smooth and clean with no visible burns to the wood. I can get the chipper to auto feed when I hold a branch up as high as I can in the chute but I'm not sticking my arm too far in there to hold up the branch.
I checked the height if the roller and the feeder roller is as close to the repaired dummy roller as it can be due to the design. I watched the rollers and the bottom roller doesn't seem to want to roll and the feeder roller just chews the branch rather than feeding it into the blades.
Any ideas? Also I am not sure of all the terminology for the chipper. Again I cant find a make or model anywhere on the chipper to help but it's a yellow PTO operated chipper.
Any help would be appreciated!
