Universal mini attach system for light duty FEL
   / Universal mini attach system for light duty FEL #1
AJBelayer
Custom
I have a 1970s large lawn tractor (Or maybe its a compact tractor, don't really know what it is, maybe a Sears Suburban 18) a that has hydraulic FEL someone built on it before I bought it, after some research it seems the tractor is rated for ~800lbs on the front axle, the loader I suspect will out lift that by a lot as its massively overbuilt. The distance between the arms is about 25 inches.
The bucket I have is really small, maybe 1/8 cu yard or smaller with some pretty aggressive teeth. I am hoping to get a smooth edge bucket for general dirt and snow moving, something for log/branch/brush moving (not cutting) with grapple, pallet forks, maybe something else.
The question is what (mini) universal attach system should I get? I know there is skid steer universal attach but at 44" minimum that is larger then what I want. I see a Toro Dingo, Bobcat MT, maybe a couple others I have read about that are more appropriately sized for my small FEL but which one?
I have access to welder and skills as needed.
Thanks in advance for any help and recommendations.
AJ
   / Universal mini attach system for light duty FEL #2
I would go with the Toro,Dingo,Ditch Witch style adaptor plate if you can find one. I just sold a set of mini forks for $200..so there are lots of attachments you can use
I found the ETERRA MINI UNIVERSAL ADAPTER MQT-100 on Skidsteer.com site but it say may have some compatibility issues with Toro attachments, are Toro attachments a big part of the market share or should I not be worried about it?
Also is $500-ish a good or bad price in everyone's opinion for such an adapter?
Thanks for the input!
2012 Jeep Grand Cherokee SUV (A56859)
2012 Jeep Grand...
Voltage Converter, Single Phase, 240 Volt Input, 120 Volt Output (A59076)
Voltage Converter...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56435)
LIKE NEW 2023...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
