universal joint question
/ universal joint question #21
Close view...
/ universal joint question #23
Common?
Depends on owner or owner/operator.
As we have very small fields compare to there (1/4 of acre, or even less), and you need a lot of manouvering, it is very convinient to have PTO engaged all time, then shut it off on every corner. Especially if you have double stage clutch, and mech engagement.
BTW, I bought just a wide angle joint (about 110$) and put it on an old standard PTO shaft - yellow one. Same PTO shaft we use on manure spreader.
Another one (black joint) came with 2-row corn picker. Last year I sold it, and now I have 2 wide angle of PTO shafts /forums/images/graemlins/smile.gif
Tractor on pic has independent (hand) clutch and mech engagement. I disengaged it shortly just on very sharp turns.
Are those a Carden CV joint? The Carden style joint would have both sides of the knuckle connected to each other to help support the shaft.
/ universal joint question #25
Yes, both of them are Cardan joint shafts. And yes, internal U joints have interconnection via ball and sliding disk in the middle.
28 Gauge R Panels (A65640)
28 Gauge R Panels...
(12) John Deere 1.5bu. Seed Boxes (A65640)
(12) John Deere...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2026 WINSTON 20 Ton Tandem Tag-A-Long Trailer (A62613)
2026 WINSTON 20...
Heavy Duty Pipe (A62679)
Heavy Duty Pipe...
2017 EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
2017 EZ-GO SHUTTLE...
