Box Scraper United 672 box scraper blades
   / United 672 box scraper blades #1
bryn60
Ipswich, Qld, Australia.
Kioti DS 4510
Hi can anyone please tell me what the angle of the forward and reverse blades are on my United 672 box scraper in relation to the box and also are they both touching the ground together assuming that the box is level.I ask these questions because I purchased a second hand unit and found that the rear blade touches the ground first which brings me to the believe that the blade mounting assembly is at the wrong angle.Thanks.
   / United 672 box scraper blades #2
A friend has one I just looked at. The rear blade contacts first and is lower probably 1.25 inches at the cutting edge. Front blade is about 35 degrees and rear slightly shallower maybe 28. This one has quite a bit of wear on cutting edges that yours may not.
Hope that helps.
Hope that helps.
Many thanks skytracker it helps a lot.
   / United 672 box scraper blades #4
Have you tried shortening the top link? You should be able to adjust it so the front blade hits at the same time, or sooner, than the rear.
Yes I will give that a go as soon as the rain stops and it dries out.Thanks
20ft Bumper Pull Equipment Trailer (A51572)
20ft Bumper Pull...
BBQ Longhorn Bull Smoker (A51572)
BBQ Longhorn Bull...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
