Box Scraper United 672 box scraper blades
   / United 672 box scraper blades #1
bryn60
Ipswich, Qld, Australia.
Kioti DS 4510
Hi can anyone please tell me what the angle of the forward and reverse blades are on my United 672 box scraper in relation to the box and also are they both touching the ground together assuming that the box is level.I ask these questions because I purchased a second hand unit and found that the rear blade touches the ground first which brings me to the believe that the blade mounting assembly is at the wrong angle.Thanks.
   / United 672 box scraper blades #2
A friend has one I just looked at. The rear blade contacts first and is lower probably 1.25 inches at the cutting edge. Front blade is about 35 degrees and rear slightly shallower maybe 28. This one has quite a bit of wear on cutting edges that yours may not.
Hope that helps.
Hope that helps.
Many thanks skytracker it helps a lot.
   / United 672 box scraper blades #4
Have you tried shortening the top link? You should be able to adjust it so the front blade hits at the same time, or sooner, than the rear.
Yes I will give that a go as soon as the rain stops and it dries out.Thanks
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
Bushog 6ft Disk Mower (A51573)
Bushog 6ft Disk...
Clark G500-50 4450lbs Propane Forklift (A51691)
Clark G500-50...
2021 John Deere 9420R Tractor (A53342)
2021 John Deere...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
