Uninterruptible Power Supply running Rinnai or pellet stove?
   / Uninterruptible Power Supply running Rinnai or pellet stove?
We gave up on this idea and got a generator. Now another question. This 36,000 BTU Rinnai wall furnace does not have an external thermostat. Depending on season, we shut it off or turn it way down. We have Internet there.
Is there any way we could control this remotely? Presumably we could get a wireless on/off switch, but would like to control set point. But the only Rinnai part I've seen is for a tankless water heater.
   / Uninterruptible Power Supply running Rinnai or pellet stove? #22
Is there any way to connect an external thermostat? Many of them are wireless and can be controlled via a smartphone app.
An external thermostat isn't supported, apparently. But I think I found just what I was looking for: Belkin makes a switch plug that can be turned on and off remotely from a smartphone app.
WeMo® Switch
So I can set the thermostat on the unit then turn it on remotely. I can monitor the temp from a smart thermostat used for an electric baseboard.
   / Uninterruptible Power Supply running Rinnai or pellet stove? #24
Four group 31 sized marine batteries, 1000W of solar panels on the roof and a 1500W UPS.
   / Uninterruptible Power Supply running Rinnai or pellet stove? #25
The WeMo switch does require a wifi network. But, probably just as important, if you check the reviews on Amazon, looks kind of iffy with about 3.5 stars.
I looked at that. Most of the low reviews are due to problems with the app - and some of those are recent.
But I have had really good luck with Belkin so I am counting on them to improve it. The heater is only about five feet from the wireless hub. It's at a ski house and near the end of the heating season, so even if it takes them a while to fix the app I'll be ready for next season.
Success! I plugged it in today. First you pair it with your phone, than your network. Mine asked to do a firmware update, then asked for another. Tested it by shutting off wifi so I was using the phone network. You have to hold down the button a few seconds but the Rinnai came on! It shows a green ring when on.
FWIW Rinnai model # is RHFE-1001FA/VA-P.
Update. I was cursing this thing for a while as the network wouldn't recognize it. Then I found the wifi wasn't working. Rebooted the router and all good.
Today I turned it on while we were at a grocery store in Warner, NH, and the house was 70 by the time we got here. Sweet!
2021 JOHN DEERE 410E-II 6X6 OFF ROAD DUMP TRUCK (A51242)
2021 JOHN DEERE...
2014 Chrysler Town and Country Van (A50324)
2014 Chrysler Town...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
Category 3 Quick Hitch (A50514)
Category 3 Quick...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
