UNIMOG RESTORATION UPDATE + PHOTOS
   / UNIMOG RESTORATION UPDATE + PHOTOS #1
Von
Veteran Member, Advertiser
Western New York
Kubota B2710
Well since I have convinced the wife that the Unimog was a good investment, and is worth way more restored I have started to strip it down to the frame. Besides this is the only way to fit it into the shop to work on it! /forums/images/graemlins/wink.gif In this photo you can see that I just got the Case rear deck off. The Kubota picked it up with no problems! No small feat, as this thing is made out of 1 1/4" plate stock! /forums/images/graemlins/shocked.gif Had to do alittle cutting here and there to get it off of the frame! This thing makes my Zamboni look small, and thats no easy task! /forums/images/graemlins/smirk.gif
In this photo you can see the dump box that I removed and just some of the rust that came off of the deck and box. I already got rid of two pails full! I'll have to change the weight on the thing when I get done! /forums/images/graemlins/grin.gif
Here is the rear view of the frame. Once I get the ROPS off I can put it in the shop and remove the cab, pull the motor, trans, and drop the axles. Then sandblast the frame down and start from scratch.
I still need to find a good replacment cab for it. I am going to replace this two door cab with a 4 door crew cab. Just have to find one first! There is just too much rust in this one to even try to fix. Plus these things are so tight in there with the two door cab.
   / UNIMOG RESTORATION UPDATE + PHOTOS #5
Von,
I assume you know about it but Rocky Mountain Moggers is a great mog referance site.
MikePA - shortened long URL reference.
   / UNIMOG RESTORATION UPDATE + PHOTOS #6
Very interesting to see the inside of a Mog. Keep posting pictures. They are great and educational.
Good luck on the restoration. It looks like a lot of work, but if you're going to restore something, you might as well restore somthing with pizzaz.
Cliff
   / UNIMOG RESTORATION UPDATE + PHOTOS #7
That rear photo shows a great example of the ground clearance these beasts have with those portal axles. Thanks for the photos! /forums/images/graemlins/wink.gif
   / UNIMOG RESTORATION UPDATE + PHOTOS #8
That cab reminds me of my '71 Toyota Landcruiser. I pulled the body off and had it acid dipped. Didn't get much back! /forums/images/graemlins/grin.gif
   / UNIMOG RESTORATION UPDATE + PHOTOS #9
Von........
I have been reading all your post's but wouldn't reply since your wife wanted to have words with me.. /forums/images/graemlins/shocked.gif Now she has calmed down, I just wanted to say that the progress looks good. My brother is happy that it went to someone that can make a go of it. I also told him that you had it running already. /forums/images/graemlins/laugh.gif Take care and make it fun.....George Oh by the way, what size is your garage? Got one planned in the future.
   / UNIMOG RESTORATION UPDATE + PHOTOS #10
Rember that e-mail I had sent you?
Skid steer auger plate (A50322)
Skid steer auger...
2016 Dodge Caravan Van (A53424)
2016 Dodge Caravan...
2007 Case 580M Series 2 Loader Backhoe (A53117)
2007 Case 580M...
78'' skid steer bucket (A53421)
78'' skid steer...
2018 GENIE GTH-844 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-844...
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
