Unfortunately I haven’t found the answer or perhaps not looking in the right place.
   / Unfortunately I haven’t found the answer or perhaps not looking in the right place. #1
Reconsaw
TX1500F
I’m baffled! My Iseki TX1500F rear axle is drilled and pinned to accept the hub which can be as you know assembled onto the axle from either side.
Having said this it seems if the hub is fitted using the outer most hole on the axle (to gain more width) can the hub handle the stress put on it in this manner or should I use the inside pin hole always.
I want the most attainable width. What are your thoughts or could someone steer me in the right direction.
30in Hydraulic Forks Skid Steer Attachment (A56857)
30in Hydraulic...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
2006 International Bucket Truck (A55973)
2006 International...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
