Uneven cut - gt2550
   / Uneven cut - gt2550 #1
Ron Conlon
Hi I have a 2005 GT2550 with a "cyclone cut" deck. The problem that I have is that the middle of the cutting path is much higher than the sides. In other words, after cutting a straight path, there is a "hump" of higher grass left in the middle. I have checked that the blades are set at the same height.
I mow with the mulching plug in. On drier, shorter grass it is less noticeable, but on taller, lusher grass it is pretty unsightly. I already spend 2 hours mowing the 2 acres and don't want to have to double-mow to get rid of the stripes. Any suggestions?
   / Uneven cut - gt2550 #2
Just a few ideas on what could be causing it..
Are any of the blades bent? Is the underside of the mower clean? I mean VERY little grass stuck to the bottom of the deck. Are you running the engine at full RPM? Are any spindle bearing worn? Did this happen last season?
   / Uneven cut - gt2550 #3
Did you level the deck front to back?
It started 2 years ago, but then I had to have a landscaper mow last year due to family matters. After getting evrything ready to go over the last few weekends I mowed yesterday and said "oh yeah, I forgait about that."
I don't think I have a bent blade.
I see what you are saying about the front-to-back leveling. Because the center blade is set forward, if the deck is tilted up then the center would cut higher, correct? I'll check that out.
   / Uneven cut - gt2550 #5
Ron - don't forget to check/adj both front and rear tires air pressures per your manual before measuring/tweaking your deck....
might also do a quick visual to make sure that center blade is not either badly dulled/worn or even mounted upside down...
2022 Forest River Cherokee Grey Wolf 23MK Patriot Edition 29ft. T/A Travel Trailer (A48082)
2022 Forest River...
2001 Ford Excursion Limited SUV (A48082)
2001 Ford...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2025 KG43 UNUSED Chain and Ratchet Binder Set (A50860)
2025 KG43 UNUSED...
2006 Honda CR-V LX SUV (A48082)
2006 Honda CR-V LX...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
