Under powering tph rototiller
/ Under powering tph rototiller #1
Jerome
Elmvale Ontario Canada
Kubota L245dt
I have a 25hp Kubota, there is a "good used" tiller coming up at action but it is rated for 35-40hp. would I be able to use it and just go as deep and have to do multiple passes or would I damage the tractor <font color="orange"> </font>
/ Under powering tph rototiller #2
If you remove some tines you can get it down to a manage HP.
Probably remove all tines from the two outside flanges may do the trick.
Egon
/ Under powering tph rototiller #3
My tiller seems to put less stress on the tractor than pulling a box blade. I have my skid shoes set at 2". The Bota can chug along at 1/2 throttle and barely notices the drain from the tiller.
When I have the shoes set all the way for depth, the angle of attack on the soil is severe, so the tiller bangs and bounces and hammers. With the shallow cut, the blades slice through the soil and it is smooth as silk.
With multiple passes, the skid shoes are 2" deep plus the depth of the previous cut, so it goes down with multiple passes.
I would not be afraid of the larger tiller, assuming your 3PH can lift it ok.
One consideration is if you have rocks, to see if it has a slip clutch. Mine does and it is nice when it grabs a rock or root. I'd price a local new unit set up with a clutch, and figure your auction price as a percentage of that.
Ron
Hey great idea, and when I talk <font color="pink"> SWMBO </font> into a larger tractor I would still be able to use it.
Caterpillar D4H Series 1, 2, and 3 Dozer Service, Parts and Operation Manuals (A63117)
Caterpillar D4H...
Yale 5K Forklift (A63688)
Yale 5K Forklift...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A61572)
2025 Mower King...
213095 (A64276)
213095 (A64276)
