Under fence mower,?
/ Under fence mower,? #11
was thinking three point or pull type, (no ATV here), so it would be tractor pulled,
Has any one built one?
If so what did you do, and what would you not do or redo if rebuilding?
I do not know weather to build a sole purpose under fence only mower, or some type of attachment to my 10 foot mower that is on three point,
what would you suggest for power source?
A large vertical shaft lawn tractor type engine, 12 horse min, preferable 20 hp, belt drive?
hydraulic motor most likely belt or chain drive?
or PTO gear box?
what would you make the blades like?
swingng like on most tractor type mowers, (bush hog style)
disk with sycle blades bolted or rivited,
use small cable and make a industral type weed eater, (note: this not ground person ran)
I like the looks of this unit in general,
this unit looks good, The Fence Mower FM 60: Fence Mowing Made Easy!
this one has the little trailing wheels that in our blow sand, I doubt would be that efficient, and the Castor action of them may be limited,
Fence runner mower mows under fences around posts
not sure if the picture will come through below, but was wondering about some thing like but mounted behind my 10 foot mower, on one side, (I guess depending on the mounting one could possibly switch from side to side, was thinking of using a guard that would rotate so it would roll around the posts,
http://quadmoto.com/bilder/produkte...el-und-Zaunspezial-Maeher-Trimmer-Swisher.jpg
We use a beltdrive sickle mower and a tractor with PS to mow under 300+ acres fences every year. Posts range from 12 apart to 45 ft apart. Takes a couple days. Ken Sweet
Thank you every one for your responses,
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
2019 Deere 35G (A60462)
2019 Deere 35G...
2020 PETERBILT PB337 SERVICE TRUCK (A59823)
2020 PETERBILT...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
TAKEUCHI TL6R SKID STEER (A59823)
TAKEUCHI TL6R SKID...
