Under deck cleaning safely
   / Under deck cleaning safely #1
Camo Kubota
South Western PA
Kubota BX2230d diesel
Looking for suggestions on safest way to pressure wash the underside of deck while attached to tractor. I used a floor jack and lifted up front end, but didn't feel it was very safe.
60" belly mower on BX 2230, front end loader is NOT attached and will not be put on.
Any suggestion is appreciated.
   / Under deck cleaning safely #2
How about a right angle or adjustable angle nozzle for your washer?
Combine that with a pair of common automotive oil-change-style ramps.
Bruce
   / Under deck cleaning safely #3
They sell right angle wands for pressure washers, but I'm not sure how well it would work.
   / Under deck cleaning safely #4
Personally, I wouldn't trust a floor jack, as a leaky seal could give you a nasty surprise. I'm also not a fan of "most" jack-stands.
I don't currently have a rotary cutter - but - I think I would raise it and put a few cinder blocks on each side. That is - unless someone on here tells me why that is a stupid idea :)
   / Under deck cleaning safely #5
Take it off and flip it over to clean it properly. Very tough to do while still attached using a right angle spray wand. Once its clean give the bottom a new coat of siliconized snow plow paint or epoxy to prevent future sticking and easy clean up.
   / Under deck cleaning safely #6
I wouldn't use cinder blocks (CMU) for supporting any large amount of weight, they just are not that strong and will crush easily. I would more easily trust a jack stand as a safety measure while using any type of jack that is rated for the weight (3000# is about total weight of that tractor) Jack it up, put the stands under it for safety but leave the jacks under it also. You can clean it effectively without getting your body underneath the tractor by using the pressure washer wand.
   / Under deck cleaning safely #7
I'm wondering if it would be easier to never clean it and just resign yourself to replacing it every 10-12 years. I pretty must have done this with my lawn tractor and the deck is still goin strong after 13 years.
   / Under deck cleaning safely #8
I'd wonder if a replacement deck could be found after that many years. The grass buildup would really affect mowing quality and eventually become unbearably loud. I take mine off and stand it up with mower axles. This creates a very stable and accessible position to scrape, pressure wash, and repaint.
   / Under deck cleaning safely #9
If the floor jack is high enough just build a pair of wood stands to go under the front wheels. Don't use hollow concrete blocks because they will fail suddenly without warning.
   / Under deck cleaning safely #10
One thing I learned from my Dad at a young age was the value of solid blocks of wood. I have a large stack of varied dimension wood blocks. If something is up in the air and I'm under it at all, I stack blocks under it in case something were to let go. Never trust hydraulics to support a load.
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
1838 (A51248)
1838 (A51248)
12" x 16.5" Kubota RTV-X1140 Tires (A52377)
12" x 16.5" Kubota...
2003 Acura Tl Sedan (A51694)
2003 Acura Tl...
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
