Canopy Under Canopy Accessory Bar PT425
/ Under Canopy Accessory Bar PT425
<font color="blue"> I forgot that you had armrests, do you use them very often or pull them up?
I am usually operating at full speed. After dumping a load of dirt its high speed back to the site. Holding on to the ROPS bar keeps me somewhat in one position.
</font>
I use the armrests a lot because they fall down into position by themselves! /forums/images/graemlins/tongue.gif
When I am doing serious loader work(sounds cool just to say it), here's what I usually do. Crowd the large bucket with dirt and then drop it to the ground as I am backing out of the pile. Then raise it an inch or two as I am moving backwards. Stick my right elbow on the arm rest, look over my right shoulder and stomp on the reverse pedal. I drive at top speed in reverse all the way across the yard or fields or wherever, slowing only for curves and hills until I get to where I'm going. Then I slow down, position the tractor and dump the load. Take off again in reverse back to the pile. This sounds really awkward until you try it. It is quite comfortable and I don't waste time turning around. The main reason I do it is because when the bucket is full, the unit is front heavy. If you try to go 8MPH forward with a full bucket and you hit a bump the rear comes up off the ground and the bucket hits the ground causing the unit to stop and the driver to slam forward. By driving in reverse, the bucket acts exactly like a wheelie bar. I can go the full 8MPH and if the unit attempts to bounce, the bucket drags on the ground instead of pushing into it. It just skids along until the unit settles down on all four wheels. Sounds dangerous, probably is, but I can move an incredible amount of material in a short time going 8MPH in both directions. As I said before, I don't do this on hills or curves, just on my flat lawn and fields. And I never drive fast with people around. Things move pretty quickly at 8MPH and your reaction times have to be quick. Better to slow down than rely on your reactions.
/ Under Canopy Accessory Bar PT425 #22
<font color="green"> Stick my right elbow on the arm rest, look over my right shoulder and stomp on the reverse pedal. </font>
This man needs one of those high speed left handed mirrors I can't seem to find anywhere /forums/images/graemlins/tongue.gif
Sedgewood
/ Under Canopy Accessory Bar PT425 #23
Do you have any concerns with the alternator being enough to power the extra lights?
<font color="blue"> Do you have any concerns with the alternator being enough to power the extra lights </font>
Yes. It is supposed to be a 15 amp alternator and the 4 lights will be pulling 35W each. So, if I got this right, 35Watts X 4Lights = 140W total. I think 140W/12V=11.7A. That leaves about 3 amps to charge the battery, run the spark plugs and the electric fan on the hydraulic cooler. I don't know how many amps that thing pulls. Add in a 35W reverse light and I'm looking at a dead battery by the end of a long evening of plowing. That is why I want to put everything on different circuits. If I don't need things, I'll turn them off. If it becomes a real hassle, I could order a 25AMP alternator kit for the Kohler, but I think I'll use my $15.00 motorcycle trickle charger on it all winter and see how things go. I never have to plow for more than 5 or 10 minutes right now anyway. When it is cold, I let the tractor warm up longer than it takes me to plow! /forums/images/graemlins/laugh.gif
/ Under Canopy Accessory Bar PT425 #25
I ended up purchasing a 300 watt magnetic heater which I put on the oil tank. Works great for our cold nights (used for the last 10 days) but I still let it stand and run for 5 minutes before going to work.
PJ
/ Under Canopy Accessory Bar PT425 #26
Pajoube,
What brand magnetic heater did you get. Local or mail order?
Duane
/ Under Canopy Accessory Bar PT425 #27
I bought it at Big R (same as TSC) and the brand name is KATZ, cost was around $49 I think.
PJ
I temped in the two new lights under the canopy by tapping into the existing headlights tonight and gave them a test. WOW! What a difference that is going to make. Hopefully, I will get them permanently wired this weekend. I think I will end up facing the original lights more outward to the sides and put them on a seperate circuit so that I can switch them off when not needed. The lights up high really get out in front of the snow blade. I'm going to like that! /forums/images/graemlins/laugh.gif
/ Under Canopy Accessory Bar PT425 #29
The picture you posted showing the new lights appear to be almost the same as what PT uses. I have not had an opportunity to run my machine in the dark, are they strong lights?
PJ
The bulbs are the same(35W tractor bulbs) but the housings are not. The ones that I added are a hard plactic housing. I'm not sure if I can change the bulb /forums/images/graemlins/mad.gif but they were so cheap, I'll just replace it if anything happens. The ones that came on the Power Trac are a softer rubber housing. They are flexible.
By the way, I found out how to take the bulb out if you have to the hard way. We had some high winds last week. We lost about a 3rd of the side of beautiful 40' Bradford Pear tree. I used the forks to pick up the rather large branch and took it to the brush pile at the rear of our yard. The branch was about 25 feet long and 8 inches thick at the butt end. Lots of side branches and still full of leaves. I was pushing it into the brush pile so hard that it jumped the loader arms, bounced against the right headlight, pushed the joystick into lift and raised itself up all the way. I had to shut off the tractor as I couldn't back up because the branch was behind the loader arm. /forums/images/graemlins/shocked.gif /forums/images/graemlins/blush.gif Pretty scarry 2 seconds!!! Anyway, I managed to get the branch off the joystick and lower the lift arms with gravity. I then had to lift the branch off the lift arms by hand. It was very heavy and I almost had to get help, but at the last second, it popped over the lift arms and I was able to start up and back away(hey, maybe I'll cross post this in the safety forum). Anyway, that's when I noticed that the rigth bulb had popped out of the housing. I just popped it back in. It is a rubber housing and it just squished back in place. Pretty forgiving. To get the bulb out of the stock headlight assembly, just use a screwdriver, slide it up along the edge of the bulb into the rubber housing and gently pry the bulb out.
As for the brightness, the stock headlights are plenty bright. However, they are at such a height that the lift arms cast a shadow directly on the quick attach. Also, I usually use the headlights mostly in the winter, due to shorter days and the need to plow the driveway in the dark. The stock headlights shines over the plow good enough, but still cast a shadow in front of the plow or a bucket, for that matter. I think Power Trac should hear this and move the lights up under the canopy on any model so equipped. It is the most logical place for them, in my humble opinion, of course /forums/images/graemlins/wink.gif
/ Under Canopy Accessory Bar PT425 #31
<font color="red"> I think Power Trac should hear this and move the lights up under the canopy on any model so equipped. It is the most logical place for them</font>
I agree.
My unit was delivered at night and the delivery trailer could not navigate my driveway (about 1300') so I had to make several trips up and down to get the attachments into the barn. The PT lights basically shined into what ever attachment I was carrying up. one of the first things I did was to move the lights up under the canopy. It is a simple job and makes a big improvement. I say simple because I just drilled two holes in the sheet metal of the canopy to mount the lights that I moved and ran a wire from the existing switch to them.
And the existing lights, just moved to the higher location are plenty bright enough, aren't they? I only added the extra set because I wanted to. Didn't need to, but it is fun /forums/images/graemlins/laugh.gif
/ Under Canopy Accessory Bar PT425 #33
Thanks for the information on the bulb.
That was a shame to lose that much of a large tree, so many years of growth that came to an end.
I may try and take the two lights that came with the PT and move them up under the canopy. I don't do much night driving but your right about winter and the short days for snow plowing.
On another note, I tried your recommended method for setting the snow blade at an angle. It took a number of tries before I found the right combination of tilt and angle to get it level. Not a fast procedure but will improve with time and use.
PJ
/ Under Canopy Accessory Bar PT425 #34
<font color="red"> And the existing lights, just moved to the higher location are plenty bright enough, aren't they? </font>
Yes--it is only the placement that is a problem in my experience.
Funny thing about that tree was, there was a large sycamore planted right next to it. The original owner of the house planted them too close together, not realising how big both would get. They started to grow together and one of them had to go. The sycamore was closer to the garage and the pool and was causing the north west side of the pear to grow funny, so I removed the sycamore last year. The NW corner of the pear started to fill in nicely where the sycamore was removed. Then this happened to the north east corner of the pear. Grrr! So hopefully, the pear will fill in within a few years. Bradford Pears are one of my favorite trees. They just naturally have a beautiful shape, bright white blossoms in the spring, dark green leaves all summer and right now there are red leaves that will last well into the winter.
Glad you got the plow angle thing worked out. The more you use it, the more natural it will become. I put my mower away last week and put the plow on with it backed into the garage waiting for the inevitable /forums/images/graemlins/tongue.gif. However, the weather has turned incredibly mild, there are leaves on the lawn out back and I might use the hand held leaf blower and the plow tomorrow for one more leaf pickup. /forums/images/graemlins/smirk.gif
/ Under Canopy Accessory Bar PT425 #36
Moss:
Did you ever think about drilling into the ROPS and running the wires up the ROPS tube and out to the lights?
/ Under Canopy Accessory Bar PT425 #37
I just strapped the wire to the ROPs pole with black tyewraps.
Yes, but I'm a little hesitant to do it. I just have a wire temporarily wraped up around the left upright until I decide what I want to do.
2015 Ford F350 XL (A57148)
2015 Ford F350 XL...
2005 Chevrolet C4500 Landscape Dump Truck (A59230)
2005 Chevrolet...
Orange County Sheriff (698) Title Brand: Police Year: 2018 Make: Ford Model: Explorer Vehicle Type: (A59231)
Orange County...
Hustler super Z zero turn (A56859)
Hustler super Z...
2012 Husqvarna LTH18538 38" Riding Mower (A59231)
2012 Husqvarna...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
