MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,209
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
<font color="blue"> I forgot that you had armrests, do you use them very often or pull them up?
I am usually operating at full speed. After dumping a load of dirt its high speed back to the site. Holding on to the ROPS bar keeps me somewhat in one position.
</font>
I use the armrests a lot because they fall down into position by themselves! /forums/images/graemlins/tongue.gif
When I am doing serious loader work(sounds cool just to say it), here's what I usually do. Crowd the large bucket with dirt and then drop it to the ground as I am backing out of the pile. Then raise it an inch or two as I am moving backwards. Stick my right elbow on the arm rest, look over my right shoulder and stomp on the reverse pedal. I drive at top speed in reverse all the way across the yard or fields or wherever, slowing only for curves and hills until I get to where I'm going. Then I slow down, position the tractor and dump the load. Take off again in reverse back to the pile. This sounds really awkward until you try it. It is quite comfortable and I don't waste time turning around. The main reason I do it is because when the bucket is full, the unit is front heavy. If you try to go 8MPH forward with a full bucket and you hit a bump the rear comes up off the ground and the bucket hits the ground causing the unit to stop and the driver to slam forward. By driving in reverse, the bucket acts exactly like a wheelie bar. I can go the full 8MPH and if the unit attempts to bounce, the bucket drags on the ground instead of pushing into it. It just skids along until the unit settles down on all four wheels. Sounds dangerous, probably is, but I can move an incredible amount of material in a short time going 8MPH in both directions. As I said before, I don't do this on hills or curves, just on my flat lawn and fields. And I never drive fast with people around. Things move pretty quickly at 8MPH and your reaction times have to be quick. Better to slow down than rely on your reactions.
</font>
