Unconventional use of M7040
   / Unconventional use of M7040 #11
Yep, I'd say that tire is pretty flat, never to be round again.
And, if I may, I'd suggest you check the air pressure in your TRACTOR front tires. In the photo, it looks like they are compressed almost to the rims under the pickup weight. I never know what I'm going to be picking up with my FEL, thus always have tires at just a couple of lbs under the max pressure posted on the sidewall. There are numerous folks on TBN who have rolled their tires off the rims because of under inflation, high load and turning corners. I fear you had two of the three required to ruin your day:eek:
That's correct, The flat was on the truck.
   / Unconventional use of M7040 #12
Oh come on! It's only flat on the bottom!! :)
Thanks for pointing out the front tires. I was distracted with the task at hand, and didn't even notice the front tractor tires until you pointed it out. I'll make a point to put some air in them when I get back out to the pasture.
   / Unconventional use of M7040 #14
The tractor also made a nice set of portable work lights.
   / Unconventional use of M7040 #15
Not unconventional. But it is using your head :) I use my fel to change flats all the time on my trailers.
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
2000 ADDCO DH1000 Message Board (A49461)
2000 ADDCO DH1000...
2012 International Semi Truck (A50323)
2012 International...
LINDE H70 FORKLIFT (A50854)
LINDE H70 FORKLIFT...
Genie GTH-644 (A50490)
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
