unbalanced
   / unbalanced #1
ktwo
Long Beach
subaru xv
What is the best method or system to use for duel fuel tanks with one main engine running off both tanks, to ensure equal returns and no overflows on either side...
   / unbalanced #2
:welcome:
To the forum from Alabama.
   / unbalanced #3
So you are saying to want to run both tanks simultaneously? To me it would be easiest to have a tube/pipe connecting the bottoms of the two tanks... assuming they are at the same level. Then you only need one pump/return.
   / unbalanced #4
I've done this before. The trouble was that the line across would always catch in the vines and dirt in the potato field. So we led a single line up over the frame. As long as we didn't run the fuel tanks dry the fuel would stay level on both sides. It actually worked really well.
   / unbalanced #5
Alternatively, mount one tank higher than the other. Fill the top, let it gravity feed to the bottom tank. Draw the fuel supply from the bottom tank and run the return line into the top tank. Thousands of tractors are set up this way.
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
2014 Ag Spray Schaben Sidedresser (A55301)
2014 Ag Spray...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2006 TerraGator 8104 (A55301)
2006 TerraGator...
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
