un un lifting day
   / un un lifting day #1
crusty 1
Platinum Member
used my 235 all day,no problems,moving gravel etc.Dug ditch to install culvert and now loader arms won,t raise but bucket will still lift tractor off the ground and 3 ph. still works.:confused2:Dave
   / un un lifting day #2
Check the Hydraulic quick connects for the FEL and see if they are seated all the way. Take them loose and hook them back up.
   / un un lifting day
dex, thanks and checked that I,m looking at the control arm bushings in the amRod or something may have come off.:confused:Dave
   / un un lifting day #4
Hopefully it isnt something costly. Can you check the pressure to your lift cylinders? Try swapping the bucket hoses to your lift arm cylinders. If it does the same thing it could be a blown seal in the cylinder.
   / un un lifting day #5
If the bucket curl can lift the tractor, I don't think you could have blown anything in the lift arm cylinders. If you put the loader in float and then try to lift the front end with the curl circuit, will that lift the loader, or is it "stuck" to the point that you still lift the tractor?
Also, as dex mentioned, hook the lift arm hoses up to the curl circuit and see if the cylinders work correctly. If that works, then you may have something wrong in the valve.
-rus-
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2021 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2021 FREIGHTLINER...
1996 Elgin Pelican Series S Street Sweeper (A50322)
1996 Elgin Pelican...
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
