un un lifting day
   / un un lifting day #1
crusty 1
Platinum Member
used my 235 all day,no problems,moving gravel etc.Dug ditch to install culvert and now loader arms won,t raise but bucket will still lift tractor off the ground and 3 ph. still works.:confused2:Dave
   / un un lifting day #2
Check the Hydraulic quick connects for the FEL and see if they are seated all the way. Take them loose and hook them back up.
   / un un lifting day
dex, thanks and checked that I,m looking at the control arm bushings in the amRod or something may have come off.:confused:Dave
   / un un lifting day #4
Hopefully it isnt something costly. Can you check the pressure to your lift cylinders? Try swapping the bucket hoses to your lift arm cylinders. If it does the same thing it could be a blown seal in the cylinder.
   / un un lifting day #5
If the bucket curl can lift the tractor, I don't think you could have blown anything in the lift arm cylinders. If you put the loader in float and then try to lift the front end with the curl circuit, will that lift the loader, or is it "stuck" to the point that you still lift the tractor?
Also, as dex mentioned, hook the lift arm hoses up to the curl circuit and see if the cylinders work correctly. If that works, then you may have something wrong in the valve.
-rus-
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
Electric Mobility Scooter (A51694)
Electric Mobility...
2013 Mitsubishi Fuso FEC92S 16ft. Reefer Box Truck (A50323)
2013 Mitsubishi...
2003 Honda 4x4 ATV (A50324)
2003 Honda 4x4 ATV...
Toro Workman HDX-D Utility Cart (A50322)
Toro Workman HDX-D...
Case SV 340 Skid Steer Loader (A52349)
Case SV 340 Skid...
