Un Identified 3 point Aerator
   / Un Identified 3 point Aerator #1
paulsharvey
Super Member
Hawthorne, Fl
Kioti CK2610 HST
Anyone know what this is? I originally just skipped past it, as I don't really need/want an aerator, but going back over the online auction, I'm wondering if that is a seed box on the rear, for over seeding golf courses or something. I do have some pasture that needs seeded, and being an odd item, I good see it going for cheap. I don't see any chains or drive wheels though, and it looks to be about 30" wide.
   / Un Identified 3 point Aerator #2
it cold be, there is a spring there
This is one seed box for sure it looks pretty similar
It sold for $150. Without really knowing more, I wasn't gonna bid over $80
it was pretty narrow, ideally you would want it to be wider then that... still pretty cheep...
So, it has to be about 30" wide, which makes me question it's intended use. It's clearly a 3 point impliment, so I wouldn't think it's for small spot areas,
   / Un Identified 3 point Aerator #6
which is pretty narrow, I agree though its not for spot area just for a baby tractor.
   / Un Identified 3 point Aerator #7
It is a very strange looking unit. If you blow up the picture, it appears the "spkes" are actually hollow, like a core aerator, but don't seem to have a way to eject the cores. The spikes appear to be replaceable.
The drum looks like the one on my Ferguson Yard Maker, which is made to be filled with water for ballast, except this one has slotted holes in the sides.
The box on the back looks like a seed box, but doesn't seem to have any type of controls or agitator, plus, I would think a seed box would be in front of the spikes (like on my Yard Maker).
I am baffled at the intended use of this attachement.
Is it possible the back box was/is intended to gather the plugs/cores for disposal? I did notice it was a plug or core type, and initially I thought the drum was solid, but you are correct, it is slotted, and open. I just can't really picture what the specific intended use is?
   / Un Identified 3 point Aerator #9
I was wondering if maybe the plugs go into the drum, then rattle around to get broken up and fall out the slots in the sides of the drum. Can't imagine that would actually work though....
It also looks like maybe the drum can be opened up like the ones you use to spread compost.
2015 International Durastar 4300 SBA 4 x 2 Water Truck, VIN: 3HAMMMMN4FL510006, Cummins Turbo Die... (A59076)
2015 International...
2016 Ram 5500 Chassis 4x4 ETI ETC37IH 37ft Bucket Truck (A56858)
2016 Ram 5500...
TUFLINE 28 BLADE DISC HARROW (A52708)
TUFLINE 28 BLADE...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
2021 Ford F-450 4x4 Crew Cab Liftmoore 3612 1.5 Ton Crane Service Truck (A55973)
2021 Ford F-450...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
