ultrasonic cleaner
   / ultrasonic cleaner #1
sherpa
Platinum Member
North Carolina Mountains
2004 NH TC33D & 2014 NH Boomer 24
What do you use for a cleaning fluid in your ultrasonic cleaner?
   / ultrasonic cleaner #2
I use Berrymans Chem Tool in my big one. I hear Simple Green Aviation cleaners is good too but never used it.
   / ultrasonic cleaner #4
I have a small one I use for cleaning carburetors and other small items. I use ultrasonic cleaning fluid. :) Which is typically whatever low-foam soap I have on hand or can find at the time. Usually, Simple Green but I have used car wash soap, windshield washer fluid and some yellow surface cleaner I can't remember the name of. They all seem to work and easy to rinse off.
   / ultrasonic cleaner #5
Just don't use a flammable liquid! Water based liquids only. If you need to use organic solvents, clean with the organics, rinse, ultrasound in your favorite detergent, and repeat as necessary.
Like @Tinhack, I use what's on hand that is preferably low foam. Alconox (high pH, works great, but don't leave alloy parts, e.g. zinc, brass, aluminum, in it for very long), washing soda, Simple Green, and even Dawn at a pinch.
I find that the design and power of the ultrasonic transducers makes more of a difference. I have had ones that just weren't well coupled to the cleaning tank and did not clean well.
All the best,
Peter
   / ultrasonic cleaner #6
Harbor freight sell a powder for use in their sonic cleaner.. it must be strong because your only to use 1/8th..teaspoon.!!
   / ultrasonic cleaner #7
I just use some Dawn in mine, seems to work good enough and I don't feel bad about just dumping it every few uses...
   / ultrasonic cleaner #8
Simple Green diluted with distilled water, 5% Simple Green is what Mikuni said to use.
   / ultrasonic cleaner #9
"Not for use on aluminum or magnesium alloys."
   / ultrasonic cleaner #10
That doesn’t apply to me..
They say possible
“dis colorization”..but it is a “warning”..not for use with..
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51692)
2015 Freightliner...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
1267 (A50490)
1267 (A50490)
