Ultrasonic cleaner recommend?
/ Ultrasonic cleaner recommend? #1
S854
Platinum Member
Helena, MT
‘67 MF 135 Deluxe / ‘22 Kioti CK2610 HST/Bad Boy ZT Elite 54”
I’m looking to purchase a bench top ultrasonic cleaner… in the 6 - 10 liter range… obviously for smaller parts… (carbs, hand tools, etc.)… Cost - $150 - $200
Lots of options… the digital ones are slightly higher priced than a comparable analog model (physical dials)… are there big differences? Worth the extra cash?
It’s gonna be used solely as a home-based gizmo… once all my old Craftsman sockets are gleaming and the carbs on my motorcycle working properly it’ll get infrequent use… probably…
Any one have one of these they’re proud of?
/ Ultrasonic cleaner recommend? #2
/ Ultrasonic cleaner recommend? #4
I have a 2.3 gallon cleaner and with most lawnmower carbs from twin engine rider engines. It really isn't deep enough to properly cover the carb to clean the entire carb at once.
/ Ultrasonic cleaner recommend? #5
I too am looking to add about a 3 gal size to my tools. Looking at the Creworks and HF.
Thoughts and other recommendations would be much appreciated.
/ Ultrasonic cleaner recommend? #8
I was looking at getting a 10 liter. But a 15 liter is only $30 more. Any disadvantages of going too large?
/ Ultrasonic cleaner recommend? #9
jus t a trick but you can start with hot water so the heater just keeps it hot instead of heating it up. I use water and put the cleaning solution in a ziploc to use less solution.
/ Ultrasonic cleaner recommend? #10
No. Normally gives you a larger tank and in some cases and you have to watch this a deeper tank but sometime the tank is shallower and just a bigger square. Also larger washers also tend to have higher transducer output. And more power tends to come in handy for larger or harder cleaning projects.
/ Ultrasonic cleaner recommend? #11
Before you buy anyone, watch this video. Turns out, many of the cheap ones aren't ultrasonic at all...
/ Ultrasonic cleaner recommend? #12
I have two Vevor ultrasonic cleaners. Both work well, but I haven’t used any others to compare them too. The first one I got for Christmas a couple years ago and it is the digital style and came with a spinner for vinyl records. I honestly haven’t used it for other things even though I’d like as I only recently learned I could put different solutions in bottles and get those dirty instead of my cleaner.
My second one is just a little one I use for cleaning glasses and watch bands. Again it works well.
/ Ultrasonic cleaner recommend? #13
I have a 10 or 15 liter one. It is too small.
I don't think the controls matter.
/ Ultrasonic cleaner recommend? #14
I have an old 5 quart model. I don't know who made it since the label is too worn to read. It isn't digital but works ok on small tools & parts, but not everything. My wife found that out the hard way when she put some of her antique jewelry in it. The ultrasonic vibration shattered the cement holding the stones in place and they all fell out of their settings. Needless to say, she wasn't a happy camper.
I guess you need to be careful what you put in these things.
/ Ultrasonic cleaner recommend? #15
I have a 10L, go with that or the 15L or whatever, just takes longer to heat up the water... I got the one with knobs instead of buttons and displays but I don't think it matters...
I've just been using some dawn in water for solution, works pretty good, hasn't been bad enough for me to get more creative, I have some pine sol and simple green like others have recommended but haven't ventured...
/ Ultrasonic cleaner recommend? #16
I have the digital Creworks 10l. Heats fast. Works great. A tip on heating, turn on the ultrasonic while heating so it circulates fluid.
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
2005 Butler pole trailer (A62679)
2005 Butler pole...
Approximately 100 Ratchet Tie Downs (A65579)
Approximately 100...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
