Ultraseal Extreme or Amerseal or ???
   / Ultraseal Extreme or Amerseal or ??? #1
Turbys_1700
Elite Member
Balls Creek, NC
New Holland t4.75
I've read some posts concerning tire sealants...
Ultraseal extreme and Amerseal seem to be two good choices out there...
Every time I go out hogging I seem to have issues with the front tires finding thorns...
Two times yesterday...
Do not want to go with foam...
What do most of you guys find the best alternative for proofing front tires for hogging tough areas?
   / Ultraseal Extreme or Amerseal or ??? #2
I'm in Central Texas (lots of Mesquite bushes!). When I first started clearing my pastures I couldn't avoid getting thorns in my front tires, with the subsequent administering of sealant foam until I eventually had to remove the tire(s) and take them to the local tire place to have the holes fixed. So I eventually had to purchase new front tires, but had them filled with foam that turns solid. Now, not only do I not have to worry about punctures and flat tires, but the foam filled tires are much heavier which is a benefit for my 2-wheel drive tractor.
Thanks for the info. I went ahead and purchased a set of new aircraft front tires and wheels from Gensco. I plan on using them for bush hogging and I'll keep the other tires and rims for less strenuous use.
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2013 Cadillac ATS Sedan (A55758)
2013 Cadillac ATS...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
2003 Big Tex 10PI...
2017 CHEVROLET SONIC (A55745)
2017 CHEVROLET...
