Ultraseal Extreme or Amerseal or ???
   / Ultraseal Extreme or Amerseal or ??? #1
Turbys_1700
Elite Member
Balls Creek, NC
New Holland t4.75
I've read some posts concerning tire sealants...
Ultraseal extreme and Amerseal seem to be two good choices out there...
Every time I go out hogging I seem to have issues with the front tires finding thorns...
Two times yesterday...
Do not want to go with foam...
What do most of you guys find the best alternative for proofing front tires for hogging tough areas?
   / Ultraseal Extreme or Amerseal or ??? #2
I'm in Central Texas (lots of Mesquite bushes!). When I first started clearing my pastures I couldn't avoid getting thorns in my front tires, with the subsequent administering of sealant foam until I eventually had to remove the tire(s) and take them to the local tire place to have the holes fixed. So I eventually had to purchase new front tires, but had them filled with foam that turns solid. Now, not only do I not have to worry about punctures and flat tires, but the foam filled tires are much heavier which is a benefit for my 2-wheel drive tractor.
Thanks for the info. I went ahead and purchased a set of new aircraft front tires and wheels from Gensco. I plan on using them for bush hogging and I'll keep the other tires and rims for less strenuous use.
2006 MGS TRAILER CAT XQ45 GENERATOR (A45333)
2006 MGS TRAILER...
2019 WYLIE EXP-500S WATER TANK TRAILER (A45046)
2019 WYLIE...
2016 TRANS TANK 8246 GALLON FUEL TANK (A45333)
2016 TRANS TANK...
2008 Ford F-250 Lariat (A44501)
2008 Ford F-250...
Case IH P110 Power Unit (A44502)
Case IH P110 Power...
2015 JCB 550-170 (A44391)
2015 JCB 550-170...
