ultimate John Deere 3120 fully Upgraded
   / ultimate John Deere 3120 fully Upgraded
purpony said:
i really love this idea you did
You have me thinking now, instead of purchasing a rear ballast box, maybe ill just by the imatch and weld a bracket on it to hang weights...... any idea what a JD weight costs?
anyone have any idea with a JD ballast box filled with concrete weights?
thanks
I have my ballast box fill with land scaping bricks slabes it weights 810 lbs and the weights on my rear blade
Frontier 2060 BB-269 lbs.
Imatch-78 lbs.
weight bracket-23 lbs
weights-210 lbs
-total 580 lbs
Matthew3120
   / ultimate John Deere 3120 fully Upgraded #32
Hey Guys the front fenders are pretty slick. Any idea if I can fit those to the front end of my 790?
I love the lighting on your tractor, of course I would have to have my light bar with a red lens.
Thanks.
   / ultimate John Deere 3120 fully Upgraded #33
So Matthew maybe you could wash & wax my tractor and I could interduce your pretty little John Deere to some real work.
Thanks.
I think if you have the same size Dia. front axle they would fit.If you could send a picture of your front axle something could be figured out to make them fit.
matthew3120
sound like a plan.I think it may a little dirt may do it some good. ha ha
matthew3120
   / ultimate John Deere 3120 fully Upgraded #36
Matthew3120-
i would like to add light switches like you did... I was wondering if you could supply a part number of the light switches you posted? or at least a tractor model number that they came off of. I was looking in the JD site on the parts finder and cant seem to find anything.
purpony said:
Matthew3120-
I will look tonite on the light switch number but the layout is my setup I put them in. I have a John Deere 3120.I will look and get you the item number.
matthew3120
   / ultimate John Deere 3120 fully Upgraded #38
The part number for the switches is MIA10204. Its funny though. I bought 2 switches at the same time. The picture on each switch was a little different. One switch had a picture of a light printed on it that was solid and colored in. . On the other switch there is a picture of the light but it is outlined. You can see the same thing in matthews picture of his switches. I wonder why the make 'em different? Maybe it's one of the reasons I bought a JD--- Attention to detail. They probably make them different to represent front and rear lighting. Either that or they get different batches from different suppliers and they don't worry about not being uniform. Not sure.
   / ultimate John Deere 3120 fully Upgraded #39
Chris-
thanks for posting the part number, however i think i got that number off one of your other posts and when i called my JD dealer they said that was not a JD part number ???
   / ultimate John Deere 3120 fully Upgraded #40
GreenRules said:
I will bet that JD Dealer LOVED you...
If you read his profile, I think he works for JD, as a tractor detailer.
BUNDLE OF USED GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF USED...
2019 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2019 UTILITY VS2RA...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
(7) DRAWER POPULAR MECHANICS ROLLING TOOLBOX (A51243)
(7) DRAWER POPULAR...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
