uh oh...MT-372 BROKE
   / uh oh...MT-372 BROKE #1
MT372HERE
I shouldnt have let it sit so long...It went unused for 9 months in my shed.
I pulled it out, put the charger on the battery and let it come up..Hit the key and it cranked right up, no problems.
Drove it around about 5 minutes and saw steam up front. I killed it and popped the hood...and the overflow was letting off prrssure. I cracked the cap and coolant was on the level as always. It only has a little leak at the pump, I usually add a quart every 10 hours of use...
So Im guessing the stat is stuck...
I dont know where to get parts...but I do work at a NAPA store, so of it's made..and napa has it, I can get it...
I need a Thermostat, oil filter, fuel filter, and a number for a water pump..or maybe a pump rebuild kit.?
It's a MT372 (2wd) and it only has about 375 hours on it. A tree fell on it in 2004 during IVAN, and I got it after it sat unused for nearly 10 years. I got it running and have been using and abusing it since..Love the machine, and the 50" Haban cuts really well.
   / uh oh...MT-372 BROKE #2
I get filters for my Buck at the local NAPA dealer with no problem. They seem to be able to cross reference whatever I need. On the water pump, I took mine to a rebuilder in Houston and the guy reached under counter and pulled out a rebuilt one and asked if I wanted to come back in three days or take the one he had. Took the one he had, fit perfectly and works fine.
   / uh oh...MT-372 BROKE #3
Oil filter Wix # 51365
Fuel filter is the long Quardrajet or at least it will work.
Don't know on the water pump or tstat.
More info coming soon! (A50323)
More info coming...
1472 (A51247)
1472 (A51247)
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
