uh-oh...DK45s won't shift out of neutral
   / uh-oh...DK45s won't shift out of neutral #11
This may not be the same problem, but it may be related. The
gear shift on my 45S was getting a little stiff and squeaking.
We found the squeak, and lubricated. Smooth and quiet again.
just a quick follow up ... thanks for all the help...I sprayed lubricant onto the vertical rod leading from the forward/reverse lever into the tranny ... I let the lubricant drip down the rod, through the floor, and downwards. This did the trick, it freed up with two or three hard pulls/pushes...gotta tell you that I had to use way more force than was comfortable to get it moving again but I've had no more problems since.
John.
   / uh-oh...DK45s won't shift out of neutral #13
just brought my dk45 to dealer only 60 hrs on it and got stuck in reverse... the dealer said they make a beefier rod that goes down in the tranny so he took care of it , but it must be a known issue
   / uh-oh...DK45s won't shift out of neutral #14
I too have the same issue w/ the forward/ reverse lever. I've never cursed so much when I was doing some FEL work this past weekend(lots of forward and reverse frustration). I hope I didn't damage anything other than my shoulder. Thanks to everyone for all the great suggestions. I'll work on it tonight after work.
David White Meridan LT6-900 Level Transit, S/N D94224 (A59076)
David White...
2020 Deere 50G (A53317)
2020 Deere 50G...
2013 ISUZU NPR STAKE BODY TRUCK (A58017)
2013 ISUZU NPR...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A56435)
2012 Ford F-150...
(3) BUG REFLECTORS IN BOX (A58374)
(3) BUG REFLECTORS...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
