3-Point Hitch UFO Control for hitch on F series
   / UFO Control for hitch on F series #1
vietvetharry
Upstate SC
Mahindra Max26XL Shuttle, Montana C4864
Landscape rake attached to the 3point hitch of my F235D will not stay in contact with the ground. The control on the UFO lowers the unit, but when I release the control the rake raises of the ground. Has anyone had this problem? Can the UFO be disconnected and the control switched over to the lever?
   / UFO Control for hitch on F series #2
Some of the F235s have a "UFO Alpha" which appears to be a completely computer controlled three point hitch (no mechanical linkage between the lever you move and the valve):( . If you have this option you could be in a world of trouble. It can not be easily converted to manual control and very little is known about how to use it or how to fix it when it breaks. We had one that we worked on for weeks. I think it ended up being a bad sensor somewhere.
The standard UFO control version only controls 1 hydraulic side link and can be unhooked completely and easily replaced with a standard adjustable side link for under $30.
Aaron
Parts@HoyeTractor.com
(940)592-0181
   / UFO Control for hitch on F series #3
they say ernie has one . I would send ernie a pm & see if he can help .Just a suggestion
   / UFO Control for hitch on F series #4
It may be common knowledge to many, but for the benefit of ignorant folks such as myself, what does the acronym UFO stand for in the UFO control being discussed?
John_R
   / UFO Control for hitch on F series #5
come on now, you know what a U.F.O. is, folkes use to see them flying around all the time :D
I couldn't resist
   / UFO Control for hitch on F series #6
I have plenty of UFO parts hovering around :eek: (4 sets)
I use the ufo feature all the time when Im rototilling or box blading the trails.
They can be a little tricky to trouble shoot when they act up. Its usually a bad ground problem.
Ernies imports
   / UFO Control for hitch on F series #7
Thanks for jumping in Ernie. Was sure most of the problem vietvet was having was due to the UFO control and lack on knowledge on its use. Hope the storm wasn't too hard on you.
Thanks Ernie, is there anyway to tell if the UFO is faulty or is it only the operator (me)? Are there any picture diagrams & instructions for setting up the dials? Are there any English text labels that can be applied?
I ordered a manual from Hoye, but they tell me the book isn't specific to the F235 and only breifly describes the UFO.
Harry
See pictures posted on other UFO thread.
   / UFO Control for hitch on F series #10
Hi Neighbor !
No storm damage here, but we lost power for 3 days
The gen set took care of that though. I had the trees limbed last summer so the wind would sail thru without damage or worry (on my part).
The best way to find how the UFO works is to hook up a tiller and play with it, thats how I learned how to use it. ;)
I saw by his pictures that he has the deluxe ufo unit, I hope he got the correct tiller with it when he bought the machine.
How did you fare thru the storm ?
Ernies Imports
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A53472)
John Deere 700...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2017 FREIGHTLINER...
