UDT Change.
   / UDT Change. #1
atk_man
Duncan, BC, Canada
1979 Kubota B7100D
What is the best way to change the UDT in the FEL system. I have a 79 b7100 with the pump on the front. Do I just pull the plug and let it drain? How do I flush out the rams?
Thanks.
   / UDT Change. #2
Since no one is answering I will try. Does your front mounted pump have a reservoir for the fluid or is the fluid contained within the cylinders? Drain the fluid out as you stated. Locate the return hose(s) to your reservoir or cylinders. If there is a reservoir, unhook the return line from the reservoir, cap the reservoir fitting off with a plastic cap and place the return line into a bucket. Poor fluid in the reservoir
while someone else works the FEL until clean fluid runs out your hose into the bucket. If there is no reservoir, you would unhook the return hose from the cylinder(s) and do the same process.
White 255 Disc (A50774)
White 255 Disc...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
Behlen Country 3 pt Leveler (A50514)
Behlen Country 3...
2008 Nautica International RIB 24ft Cat Boat with T/A Boat Trailer (A50324)
2008 Nautica...
Bobcat Skid Steer Forks (A50322)
Bobcat Skid Steer...
1999 Mack MaxiCruise CH613 (A50120)
1999 Mack...
