U5030 Engine turning socket
/ U5030 Engine turning socket
THANK YOU SO MUCH!!! That is really good information. I was worried I'd tear it all apart and not have everything I needed to get it back together. How many hours on your tractor when you did the valve adjustment? Got about 400 hours on mine now and I think it's clacking a little bit. A regular 3/4" 46mm socket is too big to fit in between the crank hub and the radiator. I'll try the alternator trick.
/ U5030 Engine turning socket #12
Turn alternator clockwise if you were looking at nut (never came off so I assume it's fine), just turn it slow, doesn't take much effort. Hardest part is tightening 12mm nut while holding the stubby screwdriver with the muffler so close when setting valve, will take some time to get adjustments right. so far so good only ran it for half hour though after finish.
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2026 Kearney 102" x 32' Gooseneck (A60462)
2026 Kearney 102"...
2021 Kubota MX5400 (A60462)
2021 Kubota MX5400...
2005 Bobcat 435 (A60462)
2005 Bobcat 435...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
