u-pull it junkyards are great things
/ u-pull it junkyards are great things #1
chucko
Polk Co , Fl
bx1800
I was helping the Brother-in-law look for a part for his old truck. I got to noticing that more cars anymore have electric radator fans. Soon after I got home I had a hole cut the the top I had build on my bota and an fan mounted to blow now on my head.
Now I am thinking if I could mount a mister below or above the fan and a small tank of water it would be just like AC
/ u-pull it junkyards are great things #2
Necessity is the mother of invention. /forums/images/graemlins/grin.gif
Don't forget the sun screen. /forums/images/graemlins/smirk.gif
Don
/ u-pull it junkyards are great things #3
That radiator fan may pull 20-30 amps so be careful not to drain down the tractor battery. Lots of airflow.
seems to be good so far. I got a small one.....helps the dust out of my face while mowing
/ u-pull it junkyards are great things #5
A while back, at a surplus electronic shop I purchased a few 4" computer fans that ran on 12 volts.
First off they are very efficient 'axial fans' and secondly they were very affordable. (think I paid no more than $10.00)
Often refered to as a 'muffin fan'.
Just a couple of weeks back I mounted one in my cab to cool me off. Worked just great and fairly quiet as well.
Also it kept the biting insects away. (mainly deer flies).
Earlier on I used one to modify an old school bus 'under the seat' heater to heat my tractor cab. The origional heater fan was a huge affair that war noisy and inefficient. Also too large for my limited cab space.
The 'muffin fan ' is only 1" thick and draws less than 1 amp.
These little guys are generally all ball bearing equipped so they spin like the devil pushing as much air as you need.
I was working in 90 deg heat, very humid without sweating to speak of.
Deffinately worth installing.
ps I mounted it at about head level, a bit to the rear, aimed (naturally) at my head and shoulders.
/ u-pull it junkyards are great things #6
Follow up:
I just checked 'muffin fan on EBay, for the fun of it.
A seller (item# 5793490853) is offering just what I was talking about for BIN @ $6.95!
It draws 660 ma @12 VDC and pushes 110 cfm's.
(that's more than your average kitchen range hood fan)
Believe me you won't regret one.
COLE 4R TWIN ROW PLANTER, 3PT (A64280)
COLE 4R TWIN ROW...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2015 Ford C-Max Hatchback (A61574)
2015 Ford C-Max...
2007 Ford F-450 Flatbed Truck, VIN # 1FDXF46P77EA72394 (A65563)
2007 Ford F-450...
Generator Motor & Wheel Spacers (A64119)
Generator Motor &...
generator trailer (A61569)
generator trailer...
