u-joints for implement shaft
/ u-joints for implement shaft #11
Thanks for the reply. I've replaced some on a couple of pickups that were high milage. Guess I have been lucky on the equipment.
/ u-joints for implement shaft #12
I had to replace a u-joint on a 6' big bee cutter due to it being left out in the weather for several seasons and fire ants building a hill around the PTO shaft. It rusted up pretty good. That probably doesn't happen too often, though. TSC had the joint I needed after I took the old one in and we compared it to their shelf stock. It was metric which made it more expensive. The yoke and joint ended up costing about $75.
Jeff
/ u-joints for implement shaft #13
Most implement U-joints are avilable at a good parts store such as NAPA. A little trick for some that don't know it is when you get a joint that won't take grease, use a little heat. It doesn't take much. Just heat the cup that is frozen and hit it with some grease. Watch out though. If it gets too hot you may have some hot grease hitting you. Once it cools a little grease it again to make certain the viscosity of the grease is good and heavy.
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A60352)
2018 Sundowner...
2024 Hurrican GF480 (A60463)
2024 Hurrican...
2022 New Holland C327 Compact Track Loader (A61307)
2022 New Holland...
