TZD25a
   / TZD25a #1
landinpoland
poland new york
Hew Holland
When first started and lifting the bucket it chatters. Acts like it has air in the system then its ok. Hydro fluid is full, is there a bleed ? Any suggestions
   / TZD25a #2
Welcome to TBN. Can't help with that, but Welcome.
   / TZD25a #3
My Workmaster 37 does the same thing. I think it’s caused by the higher viscosity of the ambient temperature hydraulic fluid on startup causing the systems pressure relief valve to chatter. This would cause pressure fluctuations in the system which shows up with the bucket doing the dance when you first lift off the ground. It disappears pretty quickly as the fluid warms up ( and thins out). It’s seems to be a LS thing as my Shibaura built New Holland’s have never exhibited these symptoms.
   / TZD25a #5
In cooler weather it's recommended to let my Kubota run for awhile before using it. This allows the fluids to come up to temperature. Start the tractor then have another cup of coffee. That should do it.
2017 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A55852)
2017 Freightliner...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56435)
2022 Brush Wolf...
2013 Chevrolet Silverado 3500 Ext. Cab Animal Control Truck (A55852)
2013 Chevrolet...
2024 Deere 333D (A53317)
2024 Deere 333D...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56435)
1992 Talbert 70...
