tz22da hydralics seem weak
   / tz22da hydralics seem weak #1
expedoman55
Hey all. I have a tz22da 07 with 125 hours on it. Garage kept and loved. My question is this. It seems that when ever I use the FEL even just to move heavy items(within reason) the hydraulics seem very weak. The tractor has little to know digging capability even in low range. Is this just cuz it is a toy or is there somthing wrong.. Btw it has ALWAYS been this way bu I am so frustrated I usually just dont use the darn FEL..
   / tz22da hydralics seem weak #2
expedoman55,
Are you raising your engine speed?
On my TC34DA I have to raise the RPM's at 1700 - 2200 to operate the loader.
Check your owners manual for your TZ22DA.
   / tz22da hydralics seem weak #3
You can have presures checked on FEL to make sure they are within specs.
   / tz22da hydralics seem weak #4
With weight on the 3pt, my fel can lift a rear tire off the ground when digging too deep and trying to lift. It sounds like yours does need to have the pressures checked.
Mine is a TZ18.
   / tz22da hydralics seem weak #5
Is it also sluggish? Make sure you are seating your quick connects all the way. Easy to check, if all good, get the pressures checked after that.
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53473)
Kubota BX2680...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
Mitsubishi 24V Electric Pallet Jack (A51691)
Mitsubishi 24V...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
